Hey, check this out dudes!
Page 1 of 1 [18 Posts]
Audio files: 51
PostPosted: Sat Jul 07, 2012 6:27 am    Post subject: Hey, check this out dudes!
Subject description: 3 chips and 1 transistor!
I can't believe the sounds, loops, drones, grooves that can be so easily cranked up on a few CMOS chips! I hate to say it, but I think I'm hooked! Cool
Majorly fixed up schem will follow soon for those who want to check it out on the board. Very Happy
7-7-12.mp3
 Filename:  7-7-12.mp3
 Filesize:  2.83 MB
 Downloaded:  227 Time(s)
We would lose our friends.
So,.........
Audio files: 51
PostPosted: Sat Jul 07, 2012 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
At first I just "fumble" the start to give an idea of the tone. A bit further in, I touched the main sequence resistor which speeds the whole thing up. It responds really well to this, and sounds quite musical. Then I started touching the sequence out resistors and diodes together. This created this great bottom end boost which really cuts through. I need to look into this.
Then, at the end, I just pull the 9V battery! Smile
So,.........
Scriabin
PostPosted: Sat Jul 07, 2012 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice sounds! --> Schematics please Very Happy
Draal
PostPosted: Sat Jul 07, 2012 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear you are getting more into it. Cool About two years ago I took the CMOS out of an old thermostat, looked at the data sheets, found this site and never looked back.
Zontar Prevails!
Inventor
Audio files: 256
PostPosted: Sat Jul 07, 2012 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wild sounds, uncle - that could be the intro to a popular song it sounds so good.
Les
Audio files: 51
PostPosted: Sat Jul 07, 2012 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
And, of course, being a Lunetta, I assume that it's an unspoken rule to record samples completely dry. That way, you can open it up in a wave editor and see exactly what's going on.
The schem I started got lost last night when I shut down the computer under the influence of the beautiful amber fluid! Crying or Very sad Laughing Cool
I'll sort it out ASAP.
BTW I think this circuit might open up a number of possibilities for ENV control of Lunetta type oscillators. This is something I think the purely digital realm of Lunettas is lacking in.
So,.........
Audio files: 116
G2 patch files: 317
PostPosted: Sat Jul 07, 2012 4:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked not the uncle too Laughing
Nice sounds!
JingleJoe
PostPosted: Sun Jul 08, 2012 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Those are the sounds I want to make! They're great for ye olde chiptune rayve.
P.S. eagerly awaiting schematics too.
As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Audio files: 51
PostPosted: Mon Jul 09, 2012 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the schem,
I'll update soon with proper designators, and there are some ideas I want to add as well, but for now, all the values are what I've got on the breadboard.
 Filesize:  35.34 KB
 Viewed:  253 Time(s)
So,.........
Scriabin
PostPosted: Mon Jul 09, 2012 8:24 am    Post subject:   Reply with quote  Mark this post and the followings unread
Thank you! I think I got the functional principle of the circuit and will breadboard it when there's some spare time
JingleJoe
PostPosted: Mon Jul 09, 2012 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah You're power starving the 40106 Smile makes sense now, one could also add interchangle outputs from the 4017 for a different sequence.
Audio files: 51
PostPosted: Mon Jul 09, 2012 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes,
The sequencer part could be expanded to enable any type of 1-10 stage pattern, and the resistors from that matrix could be variable (like a baby 10 -> APC).
The diodes really don't do much at the moment, I included them because they are on the breadboard, and I've assumed they are having an effect (although small) on the "instant biasing" of the transistor. I'm more interested in that biasing, and how they could give controlled starvation of the 40106 oscillator. The diodes would be needed to send a separate pulse stream to a second transistor/40106 oscillator block. This will follow soon hopefully.
I also want to try a three stage oscillator (using the unused inverters of U3) This could then have extra "filter" components tapped off the middle inverter. I'm thinking capacitive coupling, diode clamping, partial bypass with high value resistors, or, more likely, a combination of these effects. But I wanted to get the basic idea going first.
The decayed starvation of Q1 with the cap to ground from the base, is also a major part of getting this kind of sound. It too could be tweaked, or mixed with other conditioning of the pulsestream.
So,.........
Inventor
Audio files: 256
PostPosted: Mon Jul 09, 2012 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Uncle, reading that last post - I can't help but think that you're becoming a circuit designer! You have a lot of experience now and it shows. I look forward to seeing what else you come up with in the world of Lunettas.
Les
Audio files: 51
PostPosted: Tue Jul 10, 2012 1:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Les,
That really does mean a lot to me, especially from you! Very Happy
Yeah, it's fun playing with these things.
Not sure what to do with the end result yet, but I'm sure it will happen somehow. Laughing
So,.........
JingleJoe
PostPosted: Fri Jul 13, 2012 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got disenchanted with the filter circuit I was working on so I did this tonight instead. Turned out to be brilliant Very Happy
I've got some serious control going on too, I made an LFO to control the transistor and got some incredibly crunchy sounds out of it, I will post a video of them tomorrow.
What I'd like to try is wiring up the transistor like the simple transistor inverter; 10k~100k on the base, 470ohms~1k on the collector, power the circuits from the collector.
Reason being that things got a bit perculiar (which can be good) but this resulted in very high frequency oscillation when the transistor was in the "off" state. Also the output wave was pushed up against the top rail of the PSU, due to the circuitry being "on top" of the transistor. To summarise all problems observed; the transistor is on the ground side of the circuit, so pushes the resulting output wave up untill it gets very small and biased right up to the top rail, then it all oscillates in really high frequency. The inverter method should remedy this Smile
Anyways, that was fun, thanks for the ideas Uncle Krunkus and thanks to Dougseidel for pushing me to do this Wink
RF
Audio files: 28
PostPosted: Fri Jul 13, 2012 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome to the cult Uncle. Smile
great sound.
bruce
www.sdiy.org/rfeng
JingleJoe
PostPosted: Sat Jul 14, 2012 3:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again Uncle K Wink
For this arrangement I put four oscillators (made with random parts from my work bench) into three 4070 EXOR gates. All oscillators and gates are starved.
The saw-ish LFO controling the transistor is made with a 555 timer (556 acctually, but I only used one).
JingleJoe
PostPosted: Mon Jul 16, 2012 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
A little update, the transistor-inverter method does work, and with better control. With that method, earlier today, I made this sound I've wanted to make for ages, but it turns out I was accidentally powering the starved portion of circuit through an un-used cmos gate IC. So that was going wild and adding new timbres.
I'm working on a proper device which uses these ideas Smile Should be finished tomorrow.
