How to route the pitch stick out thru MIDI send modules?
Page 1 of 1 [8 Posts]
Robby
G2 patch files: 6
PostPosted: Tue Mar 29, 2005 1:05 am    Post subject: How to route the pitch stick out thru MIDI send modules? Reply with quote  Mark this post and the followings unread
I'd expected that if I connected the KBD input modules "pitch" output
(instead of "note" output) to a MIDI Note send module, that it would
route pitch bend (& glide) info as well as notes. It doesn't.
So - how do you do it? There are prog change send modules,
and control send modules, but no pitch-bend send modules.
So how can you route the pitch-stick out thru a MIDI send?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Tue Mar 29, 2005 1:16 am    Post subject: Re: How to route the pitch stick out thru MIDI send modules? Reply with quote  Mark this post and the followings unread
AFAIK you cant, must be coming in a future rel Rolling Eyes
It is a pity because PB is the only midi command that is both signed and 14bit.
davep
Audio files: 10
G2 patch files: 73
PostPosted: Tue Mar 29, 2005 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm. Are you maybe using the wrong module? It seems to me that the kyd module SHOULD work, but what happens if you try using the controller module instead (the one with individual outs for stick & wheel?
Dave Peck
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Tue Mar 29, 2005 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
i was making some prototype gizmos this past weekend that use the pitch bend stick as a control. attatched is a demo, with the constant knob assigned to midi cc #20.
edit: added a picture since it may be quicker to just look at and implement
 Filesize:  16.75 KB
 Viewed:  9336 Time(s)
pitchstick_demo.pch2
patch that shows use of pitch stick as a generic midi controller via CC
 Filename:  pitchstick_demo.pch2
 Filesize:  863 Bytes
 Downloaded:  1519 Time(s)
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Tue Mar 29, 2005 8:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
on second thought, I'm not sure how you are going to be using this and I don't know if my previous post (or this one) will help. here is another patch that controls pitch:
 Filesize:  27.29 KB
 Viewed:  9333 Time(s)
Robby
G2 patch files: 6
PostPosted: Wed Mar 30, 2005 3:38 pm    Post subject: I think you guys misunderstand the problem ... Reply with quote  Mark this post and the followings unread
I'm not having difficulty controlling internal G2 patches with the
pitch wheel - I'm having difficulty using the MIDI "send" modules
(under the MIDI module section) to route the pitch stick to either
external gear or to patches in other slots.
I suppose for the patches in other slots I could find a way to make
some patches respond to another controller like the pitch stick, but
that won't help for external gear.
Really, I think there should be a way to send the pitch stick using the
MIDI sends ... probably I'll post this on wish list.
Nodular
G2 patch files: 7
PostPosted: Fri May 20, 2005 5:25 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm...
Why do you need to use the CtrlSend module ?
The pitch stick sends his values on the channel of the patch you are pitch-sticking, independently.
I successfully recorded pitch-stick movements on my soft-seq several times.
I was also happy to notice that I could do things like this:
1) record the notes on a midi-track
2) record the pitch-stick movements on another track while the notes track was playing
3) blend the two tracks and find out that now notes are affected by pitch stick movements.
(indeed it's no hard work to make me happy... Wink )
Am I missing the point ?
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri May 20, 2005 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Pitch bend has its own MIDI status and is not part of the MIDI Control group. It is unique in that it offers signed (+ or -) values in up to 14 bit resolution. Clavia seem to have locked it in with the keyboard midi data which is a little inflexible for a modular. Lets say you want Slot A’s pitch bend following an envelope signal in Slot B, the G2 currently has no module to make this work.
