Using rotary encoder switches with Arduino
Page 1 of 1 [5 Posts]
PostPosted: Sun Jul 08, 2012 4:07 am    Post subject: Using rotary encoder switches with Arduino Reply with quote  Mark this post and the followings unread
Does anyone know how to use rotary encoders reliably with Arduino?
ACHTUNG!
Audio files: 213
G2 patch files: 319
PostPosted: Sun Jul 08, 2012 5:54 am    Post subject: Reply with quote  Mark this post and the followings unread
This is what I used on a PIC ... not too efficient but it did the job
Code:
code LpIntTMR3IF ( -- ) // Interrupt code
    ; [ TMR3IF timer 3 overflow interrupt, must be cleared in software        ]
    ; [ Interrupts every approx. every 100 us                                 ]
    SetBSRDefault                   ; // Assure correct RAM bank
    bcf     pir2, TMR3IF            ; // Clear the interrupt condition
    ; // reload the timer
    movlw   (( <@" tmr3_time">) >> 8) & 0xff
    movwf   tmr3h
    movlw   (( <@" tmr3_time">) >> 0) & 0xff
    movwf   tmr3l
    call    <@" _CollectRawInputs"> ; // Get physical inputs into wreg bits 0,1
    ; // Decode rotary, no debouncing used
    movlw   0x03                    ; // Isolate old state
    andwf   <@" RotaryState">
    rlncf   <@" RotaryState">       ; //   shift it left over two bits
    movf    <@" InpStatus">, w      ; // Or in new state
    andlw   0x03                    ; // as the low two bits
    iorwf   <@" RotaryState">       ; // to be kept for the next round
    jr_f    <@" RotaryState">       ; // Dispatch on old/new combination
    bra     t3_rot_done             ; // 00 -> 00 nothing
    bra     t3_rot_up               ; // 00 -> 01 up
    bra     t3_rot_dn               ; // 00 -> 10 dn
    bra     t3_rot_done             ; // 00 -> 11 nothing
    bra     t3_rot_dn               ; // 01 -> 00 dn
    bra     t3_rot_done             ; // 01 -> 01 nothing
    bra     t3_rot_done             ; // 01 -> 10 nothing
    bra     t3_rot_up               ; // 01 -> 11 up
    bra     t3_rot_up               ; // 10 -> 00 up
    bra     t3_rot_done             ; // 10 -> 01 nothing
    bra     t3_rot_done             ; // 10 -> 10 nothing
    bra     t3_rot_dn               ; // 10 -> 11 dn
    bra     t3_rot_done             ; // 11 -> 00 nothing
    bra     t3_rot_dn               ; // 11 -> 01 dn
    bra     t3_rot_up               ; // 11 -> 10 up
    bra     t3_rot_done             ; // 11 -> 11 nothing
t3_rot_up
    incf16  <@" RotaryCount">
    bra     t3_rot_done
t3_rot_dn
    decf16  <@" RotaryCount">
    ; // Fall through to rot_done
t3_rot_done
    ; // Rotary done, fall through
_Int_T3_Done
    return                          ; // B/ ---->
endCode
PostPosted: Sun Jul 08, 2012 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan. Smile
How did you wire the encoders up to the PIC?
ACHTUNG!
Audio files: 213
G2 patch files: 319
PostPosted: Sun Jul 08, 2012 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pullup resistor from each input pin to Vcc, and each switch shorts it's input pin to ground when making contact.
PostPosted: Mon Jul 16, 2012 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Is something like this useful? http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1292081426
Steve
