distortion circuit for drummachine
Page 1 of 1 [17 Posts]
synthesist
PostPosted: Thu Aug 02, 2012 1:23 am    Post subject: distortion circuit for drummachine Reply with quote  Mark this post and the followings unread
hey there!
I got a mfb 522 drum machine. It is completly analog and sounds a lot like the TR808.
I breadboarded some distortion circuits and played the machine through it.
The sound is pretty o.k. but not what I am searching for.
I am searching for the distortion sound or a similar one, that you get with "propellerheads rebirth".
Can someone recommend me a circuit that would do the job?
All of the breadboarded circuits also dont wanne distort a signal out of a VCF, why is this?
thanks.
bubzy
Audio files: 64
PostPosted: Thu Aug 02, 2012 1:55 am    Post subject: Reply with quote  Mark this post and the followings unread
which ones have you tried?
_Richard_ Smile
synthesist
PostPosted: Thu Aug 02, 2012 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I tried an experimental one using a cd4069 in different configurations. with and without clipping diodes...
And I tried the audio to gate converter for the soundlab. -there is also a distortion/ amplification included. This one doesnt sound bad, but I thought maybe there is something like a circuit that's specially for drum machines?
edit:
and those circuits do not distort a signal from the VCF. Except when the resonance is turned all the way on.
jumunius
PostPosted: Thu Aug 02, 2012 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Although for guitars, I find Cook Your Own Distortion Pedal useful. In my experience, hard clipping diodes alone add something to a drum machine, although you then need a way to make-up gain.
-Jim
Psyingo
PostPosted: Thu Aug 02, 2012 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
You could try the bass fuzz, seen here
Or maybe some other kind of distortion, i love using the fuzz face on my drum machine. I also use something similar to the 4049 type distortion, and it works well.
Do you have a sample of the propeller heads distortion? That'd help narrow it down.
PostPosted: Thu Aug 02, 2012 4:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you are talking about the scream distortion, it adds a lot of noise in the upper frequency range too. you might want to try splitting the signal, sending one split through a 4069 or similar for clipping and sending the other split through an overdriven highpass filter. then mix them together.
JacobWatters.com
synthesist
PostPosted: Fri Aug 03, 2012 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I cant post a sample because the program doesnt work with my new windows.
On youtube I only find clips where they use the distortion for the TB303 and not for the beats.
@cynosure
that's a good idea - to split the signals! I am gonna try this for sure.
PostPosted: Fri Aug 03, 2012 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a sample. Sorry about my bad job riding the level pot.
The options for modifying the sound are Tone and Presence. The tone probably gives it the brighter sound along with the slight spacial reverb effect from the presence.
Try the highpass filter with a bit of resonance, but to duplicate the exact sound you might need a stereo widening and/or reverb circuit too.
drumdist.wav
 Filename:  drumdist.wav
 Filesize:  6.73 MB
 Downloaded:  1176 Time(s)
JacobWatters.com
Psyingo
PostPosted: Fri Aug 03, 2012 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Rebirth is different from reason.
The rebirth distortion only has amount and shape.
PostPosted: Fri Aug 03, 2012 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh sorry. I misread the original post. I dunno if I still have rebirth installed...
JacobWatters.com
jumunius
PostPosted: Fri Aug 03, 2012 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
So the goal here is to do a hardware emulation of a software emulation of a hardware drum machine, no?
Wink
-Jim
PostPosted: Fri Aug 03, 2012 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just record a sample with Rebirth and looked at the waveform.
It is a typical clipping type of distortion that is applied equally across all frequencies. The 4069 distortion I have used in the past has a cap to ground between the two linear amps, which is a mild lowpass filter. Just try a regular linear amp on the 4069 that has the ratio set to amplify a bit too much.
Also try an opamp instead of the 4069. Make the feedback resistor larger than the one on the input and you can overdrive the amp. Be careful though - you will be maxing it out at the maximum output level of the opamp, which is usually a volt or two below the + supply voltage.
drumdist2.mp3
 Filename:  drumdist2.mp3
 Filesize:  533.13 KB
 Downloaded:  1061 Time(s)
JacobWatters.com
Psyingo
PostPosted: Fri Aug 03, 2012 9:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've read that the rebirth distortion is a foldback type, might be worth researching. sometimes known as a waveshaper or wavefolder.
PostPosted: Sat Aug 04, 2012 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
it doent look like foldback when I look at the waveform. I can clearly see the sine wave being clipped.
JacobWatters.com
PostPosted: Sat Aug 04, 2012 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Attached is an image with a side by side comparison. I wasn't adjusting the knobs (as Psy pointed out in chat) so I wasn't seeing the other effect that the distortion has.
It looks like there are two types of distortion.
AMOUNT controls the amount a clipping distortion. In the second and third track you can see the sine wave being clipped into a square shape.
SHAPE controls a different type of distortion that adds noise and a bit of resonance to the sound. You can see that in the lower two tracks. This must be the foldback part that Psy read about.
 Filesize:  307.97 KB
 Viewed:  326 Time(s)
JacobWatters.com
synthesist
PostPosted: Sun Aug 05, 2012 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought it wouldnt be that easy.
Because it's the shape control that I like so much. But I rather keep it simple, cause there is some other projects that I wanna finish.
So I think I will just overdrive an opamp for distortion.
BTW:
I tried to split the signals with the cd4069. Very interesting results although I only build a passive highpass filter for the second split. Thats also something I want to look in closer.
richardc64
Audio files: 26
PostPosted: Sun Aug 05, 2012 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.muzique.com/lab/sat2.htm
http://www.muzique.com/lab/sat.htm
http://www.muzique.com/lab/tclip.htm
