New module preview : Sequential router
Page 1 of 1 [7 Posts]
yusynth
PostPosted: Sun Jan 17, 2010 8:18 am    Post subject: New module preview : Sequential router Reply with quote  Mark this post and the followings unread
I have just finished testing my new YUSYNTH module called Sequential Router (I hesitated to call it a sequential multiplexer).
It is meant to be an utilty module designed as a complement to Moog 960 like analogue sequencer.
The idea is to route the three rows of CVs from the sequencer to two outputs (e.g. to drive VCOs).
There are three CV inputs called 1,2 and 3 and two outputs A and B.
A SHIFT/CLOCK input makes it possible to step sequentially through the six rotary switches. The switches offer 9 routing selections.
The shift input receives a GATE signal from the first step of the sequencer.
The position of a switch defines the routing for the corresponding stage : for example A2-B1 means the CVs from input 2 are routed to output A
while the CVs from input 1 are routed to output B.
This makes it possible to create long and complex and intermangling sequences from three short sub-sequences.
It must be noted that I used Maxim analogue switches which provide nearly null resistance and can handle voltages
in the -15V to +15V range !!!! As such the inputs and outputs can be exchanged, that is, inputs become outputs and conversely !
Other fun, you can use it with audio signals, in such a case the outputs are the left and right channel and the inputs receive
any audio signal that you can sequence through and multiplex to the stereo channels.
Next is a short MP3 file demonstrating this module : the main sequence is 48 step long and build with three 8 steps subsequences.
Some additional effects were also layered from other modules and some nice arpeggio created with the P-SEQUENCER module
designed by Alain Coupel http://www.acoupel.com.
SEQ-ROUTER-DEMO
The full-circuit and assembly instruction should be made available on my site next week I think (I still need to trim a few component values)
Yves
synthnl
PostPosted: Sun Jan 17, 2010 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one again Yves!
Michel, Synth.nl
http://www.myspace.com/synthnl
http://www.synth.nl/
http://synthnl.blogspot.com/
numbertalk
PostPosted: Sun Jan 17, 2010 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very cool!!
janvanvolt
PostPosted: Sun Jan 17, 2010 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome. Also noted the P-Sequencer is a cool module...
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
dingebre
PostPosted: Sun Jan 17, 2010 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Will Bridechamber be selling PCB's and parts kits? This looks very useful for my Oberkorn sequencer.
Nice module Yves.
David
dingebre@3dphysics.net
yusynth
PostPosted: Sun Jan 17, 2010 11:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very probably, Scott Deyo said he is interested to sell a kit for this module.
Yves
iopop3
PostPosted: Fri Aug 03, 2012 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone build this one using the Switchboard PCBs? I'm having a bit of trouble having it all fit together. Rotary switches fit on PCB and in the panel holes, but the PCB is obscuring the IN#1 and OUT A jacks. If I rotate the PCB 180 degrees it'll go outside the allowed panel space. Have a MU panel made up by re:synthesis.
Not sure if Im missing the obvious here. I tested both with Switchcraft jacks and open frame ones. Rotaries are these, http://www.musikding.de/Switches/Rotary-Switches/Rotary-switch-1P12T-sealed-pcb::2849.html
Its not a showstopper - since its possible to wire it all up by hand. Finished the CV-Standard module a few months ago so I had some practice.
