  bingsatellites Mostly Ambient
The Threeler
Page 10 of 10 [235 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10
Argitoth
G2 patch files: 6
PostPosted: Fri Jul 06, 2012 9:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
egodzillal wrote:
oh btw special hello to Argitoth who gave me the will to do that wonderful threeler with his soundcloud demos !
I really appreciate that and I hope when I finally get my 4th incarnation of my analog synth together it will not only last a lifetime but I can provide many more helpful demos of individual modules help people make decisions either to invest or not invest in a module. I want to create more informative Threeler demos especially.
ShyK wrote:
On another note, there is a lack of demos so I've attached a trippy acid/trance sample for anyone who wants to hear what a super tough 3-pole filter can do in a production-ready setting.
ShyKay great sample! I like how it reminds me of Need for Speed music. Thanks!
ShyK
PostPosted: Sun Jul 15, 2012 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comment, Argitoth.
Here's another sample, not as nice and melodic, but one that shows how this filter can cope with and even enhance a steep/sharp sound that most other filters would barely cope with and turn to something tamer than it's supposed to be.
shy-threeler-technosync.flac
output 1, hp, lp, lp/hp
 Filename:  shy-threeler-technosync.flac
 Filesize:  3.06 MB
 Downloaded:  126 Time(s)
bridechamber
PostPosted: Sun Jul 15, 2012 10:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Anyone got a suggestion player for a .flac player on a Mac? Downloaded aTunes, then had to download mplayer but aTunes can't find it head banging monitor
Wanna hear the samples!!!!
PostPosted: Mon Jul 16, 2012 5:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I use Roxio Toast on my mac, but that's because I have it for other purposes already, it wasn't a deliberate purchase.
Here's one solution that's a plugin for iTunes, but I don't use it so I can't vouch for it: http://code.google.com/p/flukeformac/
ShyK
PostPosted: Mon Jul 16, 2012 11:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's another, nicer demo of this fantastic filter.
Scott, on Mac OS, other than that iTunes plugin, you could use Decibel, Clementine, Jajuk, VLC.
shy-threeler-crunchyfunky.flac
 Filename:  shy-threeler-crunchyfunky.flac
 Filesize:  5.2 MB
ShyK
PostPosted: Mon Aug 06, 2012 4:11 pm    Post subject: full track example
Subject description: Threeler is omnipotent
Turritopsis - Confusion (flac)
The link above is to a full track with the Threeler VCF processing all the sounds except percussion.
I'm posting it here since it's a very interesting example, showing not just how well it handles sounds from an analog synth, but also how it can bring a synth like the Korg WaveStation plugin into a completely new level of awesomeness.
Argitoth
G2 patch files: 6
PostPosted: Fri Sep 21, 2012 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice stuff, ShyK! I like your crunchyfunky.
I'm finally ready to put my threeler(s) back together and I'll have to make some demos. Yep, it is worth owning two for sure!
frijitz
Audio files: 54
PostPosted: Sun Sep 23, 2012 5:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Argitoth wrote:
Dave Brown was very kind and gave me instructions on using this switch. See pin layout in diagram of second link above this post:
Dave Brown wrote:
Here is the wiring diagram of the switch from the front and rear. The order
in which you wire them matches the schematic. You can swap them around if
you want a different sequence of filter modes but I would probably go with
the default.
Over on the far right of the PCB are four pads labeled J2. A1, A0, Gnd, and
V+
Connect A1 to pin 5 on the switch. Connect A0 to the other pin 5 on the
switch. Wire the various pins as follow:
On the row connected to A0:
Pin 1 Gnd
Pin 2 V+
Pin 3 Gnd
Pin 4 V+
Pin 5 A0
On the row connected to A1:
Pin 1 Gnd
Pin 2 Gnd
Pin 3 V+
Pin 4 V+
Pin 5 A1
It is just outputing a binary code to drive the electronic switches U3 and
U4.
Danger! This appears to not agree with the data sheet! Please check carefully before using!
Ian
Argitoth
G2 patch files: 6
PostPosted: Tue Sep 25, 2012 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
here's the correct wiring.
 Filesize:  10.53 KB
 Viewed:  1731 Time(s)
ShyK
PostPosted: Mon Oct 29, 2012 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's another demo with this filter.
shy-threeler-acid2.flac
it always fits
 Filename:  shy-threeler-acid2.flac
 Filesize:  4.84 MB
 Downloaded:  64 Time(s)
Niio1
