alieneYe
Posted: Tue Jul 03, 2012 8:44 pm Post subject:
paia fatman issue Subject description: constant on midi or not |
i have a fatman. i opened it the other day to re tune it. when i turned it on it just started making sound, no midi signal or anything. just output raw wave as if the gate is stuck on (yet gate LED does not light)
i sent a midi signal to it (midi LED lights) but it doesn't respond to any cv. the gate light or cv will not respond no matter the midi channel.
i've replaced every cap, every transistor, almost every IC (no replacements for dac08, or the74hc373 yet) everything else is brand new parts. oscs work, filter works VCA works, not sure about adsr because no gate is going to it.
i can get the sound to go away when i turn the velocity knob in the VCA section all the way down, not sure what that is about. all the components in the velocity sections have been replaced
nothing seems to fix it. it's a "holiday" here so i'm sure i won't be hearing from paia for a few days so i thought i'd see if anyone here has had this issue.
i have no idea what i did to it. it was working one day, but seemed to be a little out of tune, after i opened it, it started doing this.
i'm walking away now, because i feel like putting it thru the wall
thanks for any info
t |
JovianPyx
Joined: Nov 20, 2007 Posts: 1092 Location: West Red Spot, Jupiter
Audio files: 138
Posted: Wed Aug 08, 2012 5:47 pm Post subject:
Re: paia fatman issue Subject description: constant on midi or not |
Sounds like the microprocessor is freaking out. I'd look at the power, especially the 5 volts. Look with an oscilloscope too... _________________ FPGA Synth Stuff
FatMan Mods
dsPIC Synth Stuff I am formerly known as ScottG here Time flies like a banana. Fruit flies when you're having fun. BTW, Do these genes make my ass look fat? If butts had nipples, why have tits?
alieneYe
Posted: Thu Aug 09, 2012 7:32 am Post subject:
thanks,
i happened to be in edmond a few weeks ago and took it by PAIA's shop and scott helped me out with it.
the piano switch had gone bad on me. it's all fixed and workin like a champ
scott over there is a cool cat. i look forward to working on more of their projects in the future |
