MFOS wavefreaker & Dual A/R
Page 1 of 1 [5 Posts]
Audio files: 69
PostPosted: Thu Aug 16, 2012 12:02 pm    Post subject: MFOS wavefreaker & Dual A/R
Subject description: ... in blue
Hullo .
Construction time again.
I bought a wavefreaker pcb & dual AR from Ray , time to get them ready for the panel Smile .
Populated the wave freaker , just need to wire it up and i will start to the A/R's after the weekend .
Updates at next stage .
 Filesize:  499.13 KB
 Viewed:  45 Time(s)
 Filesize:  124.98 KB
 Viewed:  43 Time(s)
www.myspace.com/skrogproductions
ashleym
PostPosted: Sat Aug 18, 2012 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Dave,
Just what is your problem?
Another great looking build to add to all the others.
Helpful advice.
Great music
Why are you doing this to us?
Are all Scotsmen supermen after Sir Chris Hoy's exploits?
I know there is something in the water having spent too many good nights in Edinburgh and Glasgow. Is there anther explanation?
Once again well done and more power to your soldering iron
Audio files: 69
PostPosted: Mon Aug 20, 2012 10:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Ashleym
Smile i do enjoy mountain biking but.. im no athlete, heh.
3 projects at once is because i wanted to save by getting the panel stickers done all at once.
Actually as part of the back to work scheme , ive employed a rotting zombie whom ive trained to resist human flesh converting to love building pcbs , instead of moaning "Brainsssz" , he mumbles pee-cee-bee's ,
He's called "Bub" & reads Salems Lot & dry shaves alot (Day of the dead movie)
hehehehehehehe Wink
Audio files: 69
PostPosted: Mon Aug 20, 2012 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
100mm by 250mm aluminium panel drilled & sticker aplied , now waiting for A/R population then wiring next weekend.
 Filesize:  119.7 KB
 Viewed:  46 Time(s)
Audio files: 69
PostPosted: Fri Oct 26, 2012 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all Smile
now got the module on the test bench ready to tweek and set up.
I had a mfos vco coupled to the input for a quick audio test and a set of old headphones plugged into the output , very aggresive sounding tones , like it very much Smile , once it's all set up and nestled into the modular i'll record some sounds , looking good so far Smile.
 Filesize:  276.56 KB
 Viewed:  29 Time(s)
 Filesize:  319.71 KB
 Viewed:  29 Time(s)
