W.T.
Joined: Jul 11, 2004 Posts: 262 Location: The Netherlands
G2 patch files: 11
Posted: Mon May 26, 2008 2:10 pm Post subject:
where are al the vocoders, i am trying to make a battlestar/beastyboys vocoder so i good use some insperation i gues,  |
W.T.
G2 patch files: 11
found them  |
Tunkul
Posted: Wed Mar 02, 2011 5:22 pm Post subject:
hi to all
its not working on win 7 ... help gyus ... is it realy working on other win ???
cappy2112
Joined: Dec 24, 2004 Posts: 2088 Location: San Jose, California
Posted: Wed Mar 02, 2011 8:18 pm Post subject:
| Tunkul wrote: | hi to all
WHat do you mean it's not working?
What kind of error do you get?
Take a screenshot & attatch it to your post.
Have you installed Python?
www.python.org
Python2.6.x should work, as should 2.7.1
You need to add C:\Pythonxx to your path variable in control panel after running the Python installer. (where xx is the same version number that you installed, but without the decimal point _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Check Mate
Posted: Sat Aug 11, 2012 10:23 am Post subject:
Hi Guys,
I have a question concearning the DX2G2 converted Patches.
I converted several DX7 Patches I found on the net.
So far so good.
But now I'm wondering where the Portamento function in the G2 Patches is. Maybe someone could explain that to me. I imagined it to be like on any other Synth I know i.e. the old Rolands etc. but I cannot find where to set the glide time that the sound slides from one note to the next.
Cheers _________________ Welcome to the Future |
Joined: Apr 01, 2004 Posts: 2516 Location: Auckland, New Zealand
G2 patch files: 584
Posted: Sat Aug 11, 2012 7:27 pm Post subject:
| Check Mate wrote: | Hi Guys,
So far so good.
Cheers |
It is in the editor patch settings dialog, next to the arpeggio controls. |
Check Mate
Posted: Sun Aug 12, 2012 2:03 am Post subject:
Hi Ian,
I knew about the "on-board function" of the G2. I just thought there is an extra portamento function bulid with modules in the G2 DX- Patches.
G2 patch files: 584
Posted: Sun Aug 12, 2012 2:38 pm Post subject:
| There is a glide module in there but looks like it just adds a 9.3ms glide to the S+H waveform. You could add another but the base patch is at 50% Mem in the VA so your going to cut your max poly voice count. |
Check Mate
Posted: Sat Aug 18, 2012 11:31 am Post subject:
Thanks for your help Ian! I'll try this then.
Rokatansky
Posted: Wed Aug 22, 2012 8:40 pm Post subject:
I have installed Phyton and was using CMD console but only get "failed patches".
Any ideas?
Win 7 32
Thanks in advance |
cappy2112
Posted: Wed Aug 22, 2012 10:42 pm Post subject:
| Rokatansky wrote: | I have installed Phyton and was using CMD console but only get "failed patches".
Any ideas?
Win 7 32
Thanks in advance |
What exactly do you mean by "failed patches"?
Are any error messages displayed?
Can you post some screenshots?
Which version of Python do you have installed?
Open a command prompt,
type python, press enter
Post the python version displayed _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Rokatansky
Posted: Wed Aug 22, 2012 11:30 pm Post subject:
Command prompt says so:
"Failed patches:nm2g2*.pch" (all files inside the g2tools folder)
"failed patches:Juno.pch" (single patch insode g2tools folder)
Typing "python" or "Python" inside cmd give me this:
"python is not recognized as an internal or external command"
Running the IDLE Python GUI:
"Traceback (most recent call last):
File "<pyshell>", line 1, in <module>
nm2g2.exe
NameError: name 'nm2g2' is not defined
Python 2.7.3 |
cappy2112
Posted: Thu Aug 23, 2012 3:59 pm Post subject:
| Rokatansky wrote: | Command prompt says so:
nm2g2.exe
Python 2.7.3 |
The stupid website didn't notify me of this reply, even though that option is checked. Sometimes it happens, sometimes it doesn't. Don't know why.
Ok, so it's not in your path.
Would you do me a favor?
We need to add the python path to your system path
Type
which python
at a command prompt, paste your results here _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Rokatansky
Posted: Thu Aug 23, 2012 4:14 pm Post subject:
Got it working now.
Just downloaded the G2oolsGUI,re-installed and followed the detailed info there and everything is fine now.
I used this command :"nm2g2 -r Dirname"
Thanks for your support
Regards |
blisargon demogorgon
cappy2112
Posted: Sun Mar 10, 2013 3:24 pm Post subject:
| blisargon demogorgon wrote: | | Rokatansky wrote: | Got it working now.
Regards |
I have used the same command and out of 900 patches only 400 were converted any info how i can convert the others and why would i get that error? |
Try converting just one of the patches that failed the conversion.
I believe a log file may be generated, but I don't remember where it is or what the name would be.
Look for files with .log extension and report your findings.
It's been a long time since I've used these tools. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Posted: Sun Mar 10, 2013 3:35 pm Post subject:
| cappy2112 wrote: | | blisargon demogorgon wrote: | | Rokatansky wrote: | Got it working now.
Regards |
It's been a long time since I've used these tools. |
Just tried and i do it trough CMD.EXE
It gives me message Failed patches: FM Lead.pch
Where can i see the detailed error? _________________ http://www.facebook.com/BlisargonDemogorgonBhooteshwara
https://soundcloud.com/blisargon-demogorgon
http://bhooteshwara-records.net/ |
cappy2112
Posted: Sun Mar 10, 2013 4:05 pm Post subject:
| Quote: |
Where can i see the detailed error? |
We do know the converter has some limitations, although
I don't know exactly what they are. It won't work with every patch.
Are these patches you've created? _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
