Note detector module
Page 1 of 1 [5 Posts]
tiptaptempo
G2 patch files: 16
PostPosted: Mon Aug 20, 2012 3:50 am    Post subject: Note detector module
Subject description: Using "note detector" to walk through an other sequencer note ?
Hi everyone,
I've 3 drum triggers in the physical inputs of my G2, bass drum, snare and tom. With the tom trigger, i would like to use in order to "pass" into the others note sequencer that i've patched.
I'm not behind my gear now, but i've read that this could be able to do this with a note detector module. So if i write into the note detector module the last notes for each of my note sequencer, every time i'll HIT the tom, it will pass into the others note sequencer ?
Any Suggestion ?
Ps :The patch i use is linked to this post.
Duracell Tribute.pch2
 Filename:  Duracell Tribute.pch2
 Filesize:  2.9 KB
 Downloaded:  102 Time(s)
tiptaptempo
G2 patch files: 16
PostPosted: Mon Aug 20, 2012 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
To be more precise,
Actually i would like that the tom changes the bassline every time i Hit him.
I don't know how this can be able. Confused
Roland Kuit
G2 patch files: 124
PostPosted: Mon Aug 20, 2012 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
In 3 audio trigger them both with use of 2 logic Xor modules. Also fun to change 1 or both to Or/And etc.
duracell_tribute_149.pch2
 Filename:  duracell_tribute_149.pch2
 Filesize:  3.05 KB
 Downloaded:  129 Time(s)
Roland Kuit
http://rolandkuit.com/
tiptaptempo
G2 patch files: 16
PostPosted: Tue Aug 21, 2012 11:22 am    Post subject: Xor function Reply with quote  Mark this post and the followings unread
Hej Roland,
I must go step by step.
I've done a more clear patch to my own, and still can't get with the XOR function. the output will be on if the inputs are different. I can't link this to my patch...
My two pulse (kick and snare) must be mixed with a logic gate module, i just know a little about that.
Can you explain a little more / step by step this story, maybe references in Soundlab 1 ? javascript:opener.emoticon('Let us pray')
"cleaner" attached patch below ...
headache.pch2
 Filename:  headache.pch2
 Filesize:  2.63 KB
 Downloaded:  105 Time(s)
Roland Kuit
G2 patch files: 124
PostPosted: Tue Aug 21, 2012 1:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
XOR
A B Q
0 0 0
1 0 1
0 1 1
1 1 0
If either A OR B is 1, but NOT both, Q is 1.
It doesn't matter if you send triggers from an audio input or from the Event Sequencer to the A and B input.
What it means is that when there is a signal on 1 input, you sequencer will go 1 step further. Except with on both audio input triggering.
And when there is no triggering at all, no step forward aether Wink
Check my chapter Logic of SoundLab I you have.
Roland Kuit
Niio2
