werock
Posted: Tue Apr 19, 2011 1:56 pm Post subject:
Bit of a long shot, but has anyone got one of these boards they would be willing to part with? Maybe 1 or 2 tucked away at the bottom of your to-do pile... |
o-live
Posted: Thu Aug 23, 2012 6:54 pm Post subject:
eurorack |
hello
what is needed to change for eurorack (+12 -12 v ) application ?
also on schematic you talk about tl084 aop but in part list it's tl074
wich aop i need please ?
thank you so much for your help |
LFLab
Joined: Dec 17, 2009 Posts: 497 Location: Rosmalen, Netherlands
Posted: Fri Aug 24, 2012 5:13 am Post subject:
TL074 and TL084 are functionally the same for our applications, as is TL064, the difference is in power consumption, noise and offset, but I wonder if the difference is at all noticeable.
As for PSU voltage, I think mine is running at +/-12v without a problem. Not sure which incarnation of the SSM2044 filter this is, but you have to make sure you tie the low end side of the cutoff pot with a resistor to V- instead of ground. This increases the range, and improves the filter a lot. |
Posted: Fri Aug 24, 2012 5:33 am Post subject:
for 12V you can optimize the CV response of this circuit by changing only a few components values:
R16=100K
R11=180K
R15,R15'=22k
refer to sounds post from 2006. he achieved 16hz to 16Khz! _________________
Tech Buddy at Random*Source |
o-live
Posted: Fri Aug 24, 2012 3:14 pm Post subject:
ok for the Aop thank you
and sorry i don't have see the 2006 post i go to directly |
o-live
Posted: Tue Aug 28, 2012 5:50 pm Post subject:
hello Mathias
i have a question about the gain in input or output
it's possible to have more gain (like a distortion)
wich component (resistor) i need to change ?
i have quite finish the module ,it was hard to find at good price the tempco
thank you so much |
o-live
Posted: Thu Aug 30, 2012 5:53 pm Post subject:
hi
for more gain on input i think i can change r13 and connect directly a volume pot 50k
soldering it's finished and i have turn on the module ,and i have an issue
resonnance doesn't work correctly and i search search for wich reason when i turn pots i listen some changement but no resonnances ,just filtering .
i have try to set the trimpot of feedback (self osc) the sound come loud to thin
can you help me for know wich value (v) i need to read on different point of circuit please
in entry i have exactly 12.6v -12,3v
on tl074 11.75v -11.66v
on pin 1 have only 1.71v (with resonnace pot at max and trim pot open if i close i have 0v)
in pin 2 of ssm 2044 i have 1,71v
now i don't know where i need to search
thank for you help |
