  Faux Pas Quartet and friends Music From Last Thursday [rebroadcast]
PCB OFFER: Single Channel Attenuverter PCB
Page 1 of 3 [54 Posts]
Goto page: 1, 2, 3 Next
PostPosted: Wed Aug 01, 2012 2:26 pm    Post subject: PCB OFFER: Single Channel Attenuverter PCB
Subject description: to retrofit existing modules..
someone here on the forum asked me if i would do a PCB fo a single attenuvertion channel to retrofit CV inputs of built modules with an attenuverter. so i came up with the following DIY PCB:
Posted Image, might have been reduced in size. Click Image to view fullscreen. Posted Image, might have been reduced in size. Click Image to view fullscreen.
FlickR Set
BTW i never would have thought that the bottle cap of alcohol-free beer would work for size comparison, but it does!
i am taking pre-orders until 10 SEP 2012.
Pricing:
0,80 EUR/1.- USD each chicklet
shipping and handling TBA (but reasonable as always)
just indicate your interest by posting in this thread. i don't take any money up-front, i just ask you to be honest.
the PCB is single sided, 1.4in x .7 in (36mm x 18mm), and acommodates 9, 16, and 24mm alphas, i tried it with a 9mm vishay, too.
each PCB provides a complete power input filter/decoupling scheme, so you could even build a module from it. nevertheless, there are wirepads for the positive and negative rail after the filter, making it possible to use one filter/decoupling section for multiple daisychained PCBs.
here is the documentation.
OLD POST
someone asked me if i would do a PCB for a single attenuvertion channel to easily retrofit CV inputs of built modules with an attenuverter.
i came up with two designs, one in TH and one in SMT. now i think of doing a PCB run. TH or SMT?
the TH would be 100% DIY.
the SMT could be pre-assembled (without potentiometer) or 100% DIY, too.
the PCBs would be mounted to the panel using a PCB mounted potentiometer (i.e. 9mm or 16mm alpha)...
so i basically have three options:
TH 100% DIY,
SMT 100% DIY, or
SMT pre-assembled.
what would be preferrable?
fonitronik at
citric acid
PostPosted: Fri Aug 17, 2012 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
th diy or a pre one.
http://soundcloud.com/citric-acid-303
PostPosted: Fri Aug 24, 2012 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
finished the assembly of a prototype PCB. i will not test it now, i will have to go to bed (old farts like me need their sleep).
i tried it with a 16mm alpha, and with a 9mm vishay. they both worked well. the 24mm alpha can only fit better.
fonitronik at
PostPosted: Mon Aug 27, 2012 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
boards tested, all is working well. ready to take pre-orders...
fonitronik at
bubzy
Audio files: 48
PostPosted: Mon Aug 27, 2012 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
what would i need one of these for?
(or is this a "if you have to ask, you dont need it") Very Happy
_Richard_ Smile
PostPosted: Mon Aug 27, 2012 4:14 am    Post subject: Reply with quote  Mark this post and the followings unread
a lot of modules have a CV input. very often an attenuator is associated with this CV input.
then there are quite a few people who like attenuVERTers (or polarizers) on CV inputs.
with an attenuverter/polarizer you have full attenuation at 12 o'clock. right turn gives you the positive signal (amplification 0 to +1), counter clockwise gives you the inverted signal (amplification 0 to -1).
this little PCB chicklet is meant as an add on to existing designs, projects, modules that do not provide attenuvertion on CV inputs, nevertheless, you could build a dedicated module from several of these PCBs.
fonitronik at
donpachi
PostPosted: Mon Aug 27, 2012 8:18 am    Post subject:   Reply with quote  Mark this post and the followings unread
20 for me, please.
By the way, as of now, I seem to have about 50% fonitronik PCBs in my not-yet-finished system. Which is good Smile
These tiny boards will bring the percentage up significantly.
Danno Gee Ray
PostPosted: Mon Aug 27, 2012 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for 15 TH/DIY.
Level5
PostPosted: Wed Aug 29, 2012 12:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm in with 25
ashleym
PostPosted: Wed Aug 29, 2012 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Judging by the numbers requested so far I think these are key pieces for our modulars. Can you put me down for 20 please?
PostPosted: Thu Aug 30, 2012 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
yep.
i got quite a few inquiries over at muff's. however it seems that everybody has announced their need, so i could close the pre-order actually...
fonitronik at
tazer
PostPosted: Fri Aug 31, 2012 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey
I would like 10 please
cheers
Ian
PostPosted: Fri Aug 31, 2012 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
due to the quantity of order i am able to lower the price to 0.80 EUR / 1.-USD each chicklet... Cool
fonitronik at
davidschwan
PostPosted: Fri Aug 31, 2012 7:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in 20.
ashleym
PostPosted: Mon Sep 17, 2012 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just asking how the ordering is going?
LektroiD
PostPosted: Tue Sep 18, 2012 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be in for 10 (TH)
My tunes available here
(check out the new Electro-Funk LP)
PostPosted: Wed Sep 19, 2012 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
@ashleym:
to place a pre-order just post in this thread, or send me an email, or PM.
we passed the deadline allready (see 1st post), however, as allways i ordered a few spares. so still no problem to place orders.
@lektroid:
i put you on the list. thank you.
fonitronik at
crashlander42
PostPosted: Mon Sep 24, 2012 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Am i too late? Do you have any spares left?
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
PostPosted: Mon Sep 24, 2012 7:32 am    Post subject: Reply with quote  Mark this post and the followings unread
still spares left.
fonitronik at
Audio files: 27
PostPosted: Mon Sep 24, 2012 7:37 am    Post subject: I'd like to order some Reply with quote  Mark this post and the followings unread
I'd like to order 20 of them if they are available.
crashlander42
PostPosted: Mon Sep 24, 2012 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd like 12 pretty please.
My DIY stuff Flickr
Paradigm X
PostPosted: Wed Sep 26, 2012 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
ill take 10 please !
many thanks.
Wink
magneticstripper
PostPosted: Wed Sep 26, 2012 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
10 would be great (if there are any left)
numbertalk
PostPosted: Fri Sep 28, 2012 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Any spares? I'll take 20 if so.
kitsch-bent
PostPosted: Fri Sep 28, 2012 9:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'd be up for 50 if it isn't too late
AmbiphonicDSP
