7 Segment Display Problem
Page 1 of 1 [9 Posts]
bubzy
Audio files: 47
PostPosted: Thu Aug 30, 2012 1:04 pm    Post subject: 7 Segment Display Problem Reply with quote  Mark this post and the followings unread
So, im building a bpm thingy for my modular and wanted to use 3, 7 segment displays to display the bpm (i thought a 16x2 lcd display would be tacky)
it took some time, and some learning (thanks edisonrex)
but i finally came up with this.... hope it helps someone out sometime.
sorry for my messy code, its something ill probably never stop doing.
youtube vid here too
http://www.youtube.com/watch?v=aLDGO7JDEeQ&list=UUBty83q-zxoOXa0h0UfLGCg&index=1&feature=plcp
please ask any questions and offer any suggestions Smile
EDIT : updated to use 3 pins from arduino (including reset)
 Filename:  arduino 7 seg 2 pins.bmp
 Filesize:  390.53 KB
 Downloaded:  50 Time(s)
_7_seg_2_pins.txt
 Filename:  _7_seg_2_pins.txt
 Filesize:  1.46 KB
 Downloaded:  51 Time(s)
_Richard_ Smile
PostPosted: Thu Aug 30, 2012 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
So.... A BPM thingy?
If you want the arduino to simply display a BPM value, there are 7 segment driver chips (usually BCD input, like http://www.play.com.br/datasheet/CD4511.pdf) and I believe an Arduino library to drive them. It looks to me like this particular application is just testing the LCDs by displaying a upward count, is that right?
I'm just trying to get the connection between what you describe and what I see Smile
bubzy
Audio files: 47
PostPosted: Thu Aug 30, 2012 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
ouch!
thats a lot of pins Razz
this is just the start and yes this just tests the 7 seg displays Smile
i think running 21 leds off 5 pins is pretty good efficiency
_Richard_ Smile
PostPosted: Thu Aug 30, 2012 4:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a latch, so you only need one set of 4 pins (one BCD digit) and a selection method to drive any number of displays. For 3 digits, I'd use two more bits and some logic to select which driver chip I wanted to update. You do need one driver per digit, so the chip count can climb... But I could do 28 LEDs with those 6 pins Very Happy
But it's just one thing or another, there are always many ways to do this stuff. Not trying to argue with you, it was just the way i would have done it.
bubzy
Audio files: 47
PostPosted: Thu Aug 30, 2012 5:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Of course Wink
There's actually a way of using 2 pins with these chips as pointed out by blue hell in the chat earlier, but of course it's all personal preference. I used what I had to hand and learned about shift registers. I don't do arguing Smile everyone has their own opinion and their own methods, that's the beauty of this site, and this hobby Smile
_Richard_ Smile
bubzy
Audio files: 47
PostPosted: Sun Sep 02, 2012 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
dont forget a resistor to ground off the 7 seg displays Very Happy
_Richard_ Smile
bubzy
Audio files: 47
PostPosted: Sun Sep 02, 2012 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
PCB layouts here, they are a bit scrappy and currently untested, but im gonna etch and test these today.
apologies for my amateur designs Smile
as its single sided, i couldnt find a good way of routing all of the led's together, thus the layout, im going to put the 7 segs on perf and wire them from the holes on this layout.
edit: new version uploaded, messed up pins 9 and 10
7segpcb.zip
 Filename:  7segpcb.zip
 Filesize:  20.34 KB
 Downloaded:  34 Time(s)
_Richard_ Smile
Mdashdotdashn
PostPosted: Mon Sep 03, 2012 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
If you want to use a ready-made display (although it might be less fun), check out
http://www.adafruit.com/products/772
Uses only 2 pins. I'm using it together with a MIDIvox and it works quite well.
Marc.
bubzy
Audio files: 47
PostPosted: Mon Sep 03, 2012 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
i intentionally steered away from those displays on this project Smile although i have used the lcds on other projects Smile
_Richard_ Smile
