LM13700 Wasp filter (untested)
Page 1 of 1 [9 Posts]
ickystay
PostPosted: Tue Dec 16, 2008 11:16 pm    Post subject: LM13700 Wasp filter (untested) Reply with quote  Mark this post and the followings unread
Will an LM13700 work to replace the two CA3080's in the Wasp filter? I don't know. I seem to recall guys using them in their DS-7 clones.
Anyway, I made a layout to try. I feel funny posting this among the pro looking PCB's you all fashion, but what the heck. Maybe the electrons wont mind.
This is the Juergen Haible version. Check his site and pick up the schematic here (you'll need it):
http://jhaible.heim.at/tonline_stuff/hj_wasp.html
The PCB will need to be flipped for PNP. Resize to 600dpi or 6 X 6.84 cm or 2.362 X 2.693 inches. No resampling.
Sorry for not testing this.
 Filesize:  45.4 KB
 Viewed:  261 Time(s)
 Filesize:  38.87 KB
 Viewed:  265 Time(s)
vtl5c3
PostPosted: Wed Nov 25, 2009 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should work. I remember seeing something in electronotes about the 13x00 being a drop in replacement for the 3080, as long as you overlooked the new features (diodes at the inputs, output buffer).
PostPosted: Thu Nov 26, 2009 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
IIRC it is partly even the same IC layout, just with some add-ons (diodes, buffers).
fonitronik at
n.d
PostPosted: Sun Feb 05, 2012 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
So, did anyone test this?
isak
Audio files: 9
PostPosted: Sat Sep 01, 2012 11:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys.
Some one test this?
I prefer to use LM13700 instead of 3080.
Is it verifid?
Isak E.
Audio files: 29
PostPosted: Sun Sep 02, 2012 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't make this PCB, but I made two Wasp filters following the schematic and replaced the 3080's with LM13700. It works fine. Apparently it is the exact same IC on the inside, but a few extra features in the LM13700.
jacobwatters.com
isak
Audio files: 9
PostPosted: Sun Sep 02, 2012 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for your reply.
Can you please share the layout you used?
Isak E.
Audio files: 29
PostPosted: Sun Sep 02, 2012 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I just used perfboard and made it up as I went. The schematic was easy to follow and everything worked on the first try (which doesn't happen half the time I solder something).
jacobwatters.com
isak
Audio files: 9
PostPosted: Sun Sep 02, 2012 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you:)
