lfo schematic
Page 1 of 1 [4 Posts]
andrew
PostPosted: Mon Mar 28, 2005 1:57 am    Post subject: lfo schematic Reply with quote  Mark this post and the followings unread
hi all, can anyone tell me what the LFS connection is for and where it connects to, i cant find it mentioned anywhere else, or see it on the other schematics
can anyone help?
cheers
andrew
paul
PostPosted: Sat Apr 02, 2005 11:58 am    Post subject: good question Reply with quote  Mark this post and the followings unread
Shocked
hey andrew,
I've builted first SL (now I nearly finished the second one) and I did not realized about it before! Embarassed
I wired-up from from S18 (pin 1) to R92 (pin 1) only but you are right, the connection goes to point LFS too!
Ray where are you!!!! Confused
ciao
paolo ferrari
G2 patch files: 584
PostPosted: Sat Apr 02, 2005 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks like an pre-level control LFO output, I guess if you use modulation level controls on your CV inputs, you would connect then to this point.
So for example you could be modulating the Pulse Width a lot and add just a little FM.
adhdboy
PostPosted: Wed Apr 13, 2005 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
It is the LFO output before being voltage divided on the LFO level pot. It would be a goo place to tap off of if you wanted to add dedicated pots for LFO level for each module. LFS = Low Frequency Source.
There 10 kinds of people in this world that understand binary those that do and those that don't.
Niio2
