Posted: Sun Sep 02, 2012 1:41 am Post subject:
PSU/AMP Trouble shooting question Subject description: Is the real problem a leaky cap? |
This is a PSU (and partial amp) PCB for a bass amp I'm trying to fix.
It's pretty obvious TR4 (at the top) has shat itself from the smoke and burns on the PCB. It's a 2SD600K which I'm in the process of tracking down or working out an equivalent. (anyone know of any good free transistor equivalence tables on the net? Something you can fiddle figures on, and it just updates the list of replacement parts automatically? Am I being unreasonable there? Have I just invented it? )
The other power transistor is a 2SB631K which looks okay.
The two on the side are 2SA1268, and look good.
The other smoke mark is where the mystery transistor was. Same case as the 2SAs, but I went to wipe the smoke off the case, and the part number simply wiped off with it!
So,....
Has anyone any idea how to work out what it was? Or does anyone want to help me work it out from first principles?
BTW The amp is a "Magnum CG 30B". Looks about 15-20 years old, made in Korea.
Description: |
Filesize: |
128.18 KB |
Viewed: |
159 Time(s) |
_________________ What makes a space ours, is what we put there, and what we do there. Last edited by Uncle Krunkus on Fri Sep 21, 2012 5:45 pm; edited 1 time in total |
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Sun Sep 02, 2012 2:42 am Post subject:
this is kind of a pointless post but,
i have a transistor selector book here, its got over 27,000 transistors in it but your one doesnt come up, the 2sd600 is in there but has no equivalent, unless someone has manufactured one since this book was written. but if you need any others, give me a shout and i can check the book. _________________ _Richard_ |
JingleJoe
Joined: Nov 10, 2011 Posts: 878 Location: Lancashire, England
Posted: Sun Sep 02, 2012 4:37 am Post subject:
Re: PSU Trouble shooting question Subject description: What is this transistor? |
Uncle Krunkus wrote: | (anyone know of any good free transistor equivalence tables on the net? Something you can fiddle figures on, and it just updates the list of replacement parts automatically? Am I being unreasonable there? Have I just invented it? )
The two on the side are 2SA1268, and look good. |
http://www.rapidonline.com/ has a parametric search function for some items but not transistors unfortunately, however you could check other big suppliers like farnell and see if they do. _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
Green Dungeon Alchemist Laboratories |
Osal
Posted: Sun Sep 02, 2012 9:30 am Post subject:
Uncle Krunkus wrote: | This is a PSU (and partial amp) PCB for a bass amp I'm trying to fix.
It's pretty obvious TR4 (at the top) has shat itself from the smoke and burns on the PCB. It's a 2SD600K which I'm in the process of tracking down or working out an equivalent. (anyone know of any good free transistor equivalence tables on the net? |
http://alltransistors.com/transistor.php?transistor=19779 scroll down to the yellow link "2SD600K Equivalent Transistors" _________________ electronic-sea.net |
Posted: Sun Sep 02, 2012 1:46 pm Post subject:
Thanks guys _________________ What makes a space ours, is what we put there, and what we do there. |
stewpye
Joined: Apr 30, 2009 Posts: 49 Location: Brisbane, Australia
Posted: Mon Sep 03, 2012 12:23 am Post subject:
To work out what the transistor with the missing markings is you'll have to trace out part of the surrounding circuit. It will be either a 2SA or 2SC I suspect, but without seeing more of the circuit I can't say if it's NPN or PNP.
Stew. |
Posted: Mon Sep 03, 2012 2:22 pm Post subject:
Yeah I agree,
I'll try tracing some of it out today and see what I can find. _________________ What makes a space ours, is what we put there, and what we do there. |
stewpye
Posted: Tue Sep 04, 2012 12:47 am Post subject:
If you could take a photo of both sides straight on, mirror the bottom side and somehow make it transparent (apart from the tracks) so you can lay it over the top sides it might make it easier.
Stew. |
DES
Posted: Tue Sep 04, 2012 11:15 pm Post subject:
I did a quick search but couldn't find anything on the Magnum, but did find a picture of a Rogue CG 30B bass amp.
http://cnj.craigslist.org/msg/3154672336.html
It's on Craigslst. If it apears to be similar to the Magnum you search for schematics for the Rogue version... _________________ Dave
www.davesneed.com |
Posted: Wed Sep 05, 2012 1:22 am Post subject:
Yeah, exactly the same. Thanks for that. _________________ What makes a space ours, is what we put there, and what we do there. |
stewpye
Posted: Mon Sep 10, 2012 11:55 pm Post subject:
I think it's more likely to be an NPN transistor. I'd like to see more towards the transistor that drives it, and the resistor etc at the top of the diodes. |
Posted: Thu Sep 13, 2012 9:09 pm Post subject:
Now that I look at it like that, I think I agree. An NPN would fit in there just right. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Tue Sep 18, 2012 4:12 am Post subject:
Call off the search!!
The suspect, a 2SC3198 was last seen hanging out on an exact same PCB which came inside and exact same bass amp,..... in perfect working order!
I s'pose it's one of the perks of working in an op-shop.
Now I can fix this one, AND get a bass amp of my own. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Fri Sep 21, 2012 3:44 am Post subject:
I put the new transistors in, and, although it sounded quite good, I had a feeling there was something else lirking behind the obvious fault.
I played along with some tracks, but after about 15mins, the amp faded and went quiet. BTW This was the original fault report.( so it wasn't all just intuition.
Turning it off and then back on gave back the full sound again straight away. But then it took just 10mins, then 5, then 1,... I think you get the picture.
My first idea was a bad power resistor warming up, but the fact that you can cycle it so quickly with the power switch, makes me think now it may be a leaky cap.
What do you dudes think?
PS I'm gonna re-cap it all anyway in the meantime. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Fri Sep 21, 2012 8:36 pm Post subject:
The other reason I think it's a cap is that there is quite a thump when you power on, when you turn on the brightness, when you switch the EQs, etc.
Now a bad cap might put a DC component on the ground line yeah? So the bypass cap for each section would make a thump as they were switched in or out. Does that make sense? _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Mon Sep 24, 2012 3:43 am Post subject:
I don't know if anyone is still out there, but I'm gonna document the end of this anyway, just for reference sake.
Okay I removed and ordered the main filter caps, (2*3300u42V) and while I was on the E14 site, I also found the main transistors, (which I also haven't checked yet) and they could be handy, cos if one of them has gone short base->emitter, I'm pretty sure that would cook the preceeding transistors. Any substance to that?
So I got 4 of the caps and 3 each of the BDX53/4C pair. Remember, I now have an exact copy of the amp for myself, so some spares are a good idea, as I plan on getting to know this amp fairly well. (I'm thinking about tricking mine out with a chorus or something grungy, or both! )
In the meantime, I've replaced the rectifier, power resistors, the other 5 caps, and all the higher wattage resistors. Mostly just cos I found I had them all in my spares, and I'm coming around to the idea of using them, cos why else would you keep all this stuff if you don't use it?
If the problem's still there, it would have to be the power transistors. Or an evil spirit! _________________ What makes a space ours, is what we put there, and what we do there. |
marvkaye
Posted: Mon Sep 24, 2012 4:52 am Post subject:
It's been an interesting project... I'm looking forward to hearing how it finally turns out, that you eliminated your thump and all is good. Hang in there.
<m> |
JingleJoe
Posted: Mon Sep 24, 2012 10:02 am Post subject:
Yes I've been watching your progress too, from afar, like some kind of compulsive spy. It's been interesting _________________ As a mad scientist I am ruled by the dictum of science: "I could be wrong about this but lets find out"
wmonk
Joined: Sep 15, 2008 Posts: 528 Location: Enschede, the Netherlands
Audio files: 15
Posted: Tue Sep 25, 2012 4:03 pm Post subject:
The 2SD600 and the transistor next to it just form a darlington pair, just to give it a high output current. (as hFE-darlington = hFE1 * hFE2, for us nerdies)
Any small signal transistor, for the 2SD600 a NPN, will work. I would use replace the small signal PNP on the bottom side of the PNP darlington pair with a same series transistor though, to keep the circuit a bit symmetric. _________________ Weblog! |
