PCB OFFER: Single Channel Attenuverter PCB
Page 2 of 3 [54 Posts]
PostPosted: Sat Sep 29, 2012 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
@numbertalk
@kitsch-bent
i put you on a waiting list. if noone withdraws his pre-order i will re-order the quantities you need. no problem.
fonitronik at
numbertalk
PostPosted: Sat Sep 29, 2012 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks!!
ashleym
PostPosted: Tue Oct 02, 2012 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks like these beauties will be on their way soon.
One question/idea. Does any one know of a suitable pot for this project but with a centre dent? Ideally one with a 6mm shaft as that fits the knobs I am using. I am UK based but Mouser etc have UK distribution. I have seen pots for guitars with the correct value and a centre dent but I would like to look at alternatives.
Centre dent just makes sense for the design.
PostPosted: Tue Oct 02, 2012 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
depends. in the past i tried several pots with center detent, and they all had two problems more or less:
1st, you will loose a bit of the fine control around the center detent, just because you have to move the pot 'over the brim' (i don't know how to describe that in english). what i mean: you have to move the potentiometer a little bit in order to make it stay where it is and not to move back into the detent. alas, you need linear pots (actually, read below), and thus you will be very interested in the area near the center for control voltages.
2nd, anytime the potentiometer goes back to the center detent the resistance is slightly different.
actually we needed a center taped potentiometer with detent, which has a log response CW from center, and an antilog response CCW from center. this could only be a custom potentiometer with a MOQ of 10.000pcs.
however, YMMV Cool
fonitronik at
ashleym
PostPosted: Tue Oct 02, 2012 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for those tips. I understand exactly what you are saying, I couldnt have put it better either. Even all the Fonik-fans couldnt raise an order for 10,000 pieces.... Sad
I will try a could and see what results I get
ashleym
PostPosted: Tue Oct 09, 2012 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I will try a couple and see.....
The Attenuverter boards arrived today in London. Thank you very much. They are tiny, I didnt think I had all the boards I asked for when I looked at the envelope!! The size means they will fit anywhere.
Danno Gee Ray
PostPosted: Tue Oct 09, 2012 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got the PCBs today. Thanks
keithwin
PostPosted: Tue Oct 23, 2012 1:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Late as usual, any of these left?
PostPosted: Tue Oct 23, 2012 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
i will re-order soon (together with the TH LFO). how many?
fonitronik at
dave_3283
PostPosted: Tue Oct 23, 2012 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
10, please.
keithwin
PostPosted: Wed Oct 24, 2012 4:01 am    Post subject: Reply with quote  Mark this post and the followings unread
25 please Smile
marvkaye
PostPosted: Wed Oct 24, 2012 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Put me down for 10 (to ship with my other stuff, of course)... thanx
<marv>
Audio files: 27
PostPosted: Mon Nov 05, 2012 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi! Last weekend, I installed an attenuverter on a new module and it works perfectly! Look forward to adding it to some of my existing modules.
PostPosted: Mon Nov 05, 2012 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey kevin. i am glad you liked it.
what ype of potentiometer do you use?
fonitronik at
Audio files: 27
PostPosted: Mon Nov 05, 2012 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used a 100K linear pot and a 100K trimpot. All the other values are as you specified on the schematic (all 1% resistors).
PostPosted: Mon Nov 05, 2012 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed
i meant what brand of potentiometer... 16 alpha, 9mm burnes...
fonitronik at
Audio files: 27
PostPosted: Mon Nov 05, 2012 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
Embarassed
I used an Alpha -- I'll have to get the part number to you when I get back home.
prscrptn
PostPosted: Tue Nov 27, 2012 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
... any spares available???
ke10g
PostPosted: Tue Dec 04, 2012 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I want some too please, if there are any left. 10 or so would be fine.
henrikgo
PostPosted: Wed Dec 05, 2012 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll take 10 if there's any left or you'll do a new run.
PostPosted: Fri Dec 07, 2012 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
all check PM regarding payment and orders, please...
fonitronik at
numbertalk
PostPosted: Tue Dec 11, 2012 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry for being delinquent - payment sent. Thanks!
keithwin
PostPosted: Thu Dec 13, 2012 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chick lets arrived yesterday,
Great stuff
Audio files: 51
PostPosted: Thu Dec 13, 2012 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Couldn't you add a 1M fixed from the wiper to each end of the pot, thus putting a 'hump' in it's response? Or are we looking at the reverse effect here? Just an idea.
We would lose our friends.
So,.........
Paradigm X
PostPosted: Sat Dec 15, 2012 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im sorry if this is a basic question but can you put audio signals thru this to flip the phase?
Embarassed
Thanks Smile
