Synth-DIY Experimenter Board
Page 1 of 1 [9 Posts]
KRS1972
PostPosted: Mon Oct 01, 2012 12:49 pm    Post subject: Synth-DIY Experimenter Board
Subject description: Full board in Eurorack 85T
Hello !
For the experimenter board pcb i designed a eurorack front panel, and is
almost finished.
My next step is to wire the hole thing into a 19" eurorack 3HE with power supply.
Grt,
Chris
 Filesize:  957.65 KB
 Viewed:  110 Time(s)
 Filesize:  356 KB
 Viewed:  44 Time(s)
 Filesize:  367.97 KB
 Viewed:  45 Time(s)
 Filesize:  439.18 KB
 Viewed:  54 Time(s)
 Filesize:  539.91 KB
 Viewed:  79 Time(s)
Audio files: 69
PostPosted: Sun Oct 14, 2012 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
wow , very neat & tidy , looks great Smile
www.myspace.com/skrogproductions
Etamin
PostPosted: Mon Oct 15, 2012 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Chris
That is a great panel, I agree with Dave, very neat and tidy.
May I ask, how did you apply the graphics?
Thanks, Peter
KRS1972
PostPosted: Mon Oct 15, 2012 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comment !!
For the front panel layout I use waterslide decals and a thin layer of transparent vernis.
You can get waterslide A4 decals for laser and inktjet printers.
Larger frontplates like this one I do in several parts for a better result.
(more accurate)
The decal is a bit elastic and with large pannels it's tricky to get it right.
Grt,
Chris
Etamin
PostPosted: Mon Oct 15, 2012 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Chris
Thanks for the info. Well, the decals may be tricky to use, but it looks like you have mastered it. Very Happy
Peter
KRS1972
PostPosted: Wed Oct 17, 2012 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello !!
Here I have pictures of the pcb.
Grt,
Chris
Resistors and diodes
 Filesize:  1.03 MB
 Viewed:  37 Time(s)
The kludge area now !
 Filesize:  1.04 MB
 Viewed:  40 Time(s)
loydb
PostPosted: Thu Oct 18, 2012 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome build! Would banana jacks fit in the same spaces?
KRS1972
PostPosted: Fri Oct 19, 2012 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks !
Yes, banana's will fit just fine.
Multiples 3x3 may be problem with artwork.
Grt,
Chris
 Filesize:  1.21 MB
 Viewed:  27 Time(s)
loydb
PostPosted: Sat Oct 20, 2012 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that's a little crowded. I could always replace it with another attenuation section. You should drop an email to Ray and get that panel design linked into the project page, I think it will help a lot of people.
JuneSolstice2013
