Any interest in another Quad Bass++ run of PC Boards?
Page 1 of 2 [28 Posts]
Audio files: 22
PostPosted: Wed Oct 10, 2012 4:29 am    Post subject: Any interest in another Quad Bass++ run of PC Boards? Reply with quote  Mark this post and the followings unread
I have been getting requests from several folks about bringing the Thomas Henry Quad Bass++ PC boards back into production. The documentation can be found below.
http://electro-music.com/forum/topic-53420.html
The boards will be $28.00 USD plus $5.00 flat rate shipping anywhere.
I need to have at least an order for 25 boards or more to do the production run.
Right now, no preordering, just an idea if anyone wants them.
Thanks !
LOGO by Dan lavin
 Filesize:  296.84 KB
 Viewed:  56 Time(s)
 Filesize:  150.73 KB
 Viewed:  43 Time(s)
mcop
PostPosted: Wed Oct 10, 2012 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Quite possibly. Have been thinking of doing a voice on stripboard but if a pcb's available...
What are the boards dimensions if you don't mind me asking? Would ideally like to mount this on a Euro sized panel.
Audio files: 22
PostPosted: Wed Oct 10, 2012 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
The boards dimensions are 4.7" (121mm) x 4.7" (121mm)
Kind of large which is reason why I may want top go with with a two voice version in place of four OR keep four drum voices and use SMT parts in order to produce a smaller PC board. This could be a poll also but first want to see the interest in this.
Bill
PostPosted: Wed Oct 10, 2012 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be interested, would prefer through hole to SMT, would be open to two x two voices instead of one x four, if that makes life easier for our Euro friends, assuming it doesn't mean $56 for two boards Wink.
Only really interested in one at this time though.
mcop
PostPosted: Wed Oct 10, 2012 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be happy with a 2 voice board too.
Were you thinking of all smt components or just resistors and capacitors? I'd be happy to tackle passives with a soldering iron but would be nervous of trying a chip.
Audio files: 22
PostPosted: Wed Oct 10, 2012 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
LOL Oh my no ... ! OK, thanks for your input and you make a good point also in terms of fitting into smaller form factors.
Bill
Audio files: 22
PostPosted: Wed Oct 10, 2012 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, with regards to the SMT, I will consider it but would really like to keep all components SMT. The chips would be SOIC and to be honest, I personally can solder those faster than any DIP IC and find it easier. You may just be surprised at just how easy it really is with no special equipment except a magnifier.
As far as a two voice PCB, well, that's two for two. Wink
Bill
PostPosted: Wed Oct 10, 2012 10:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would agree, if it was going to be SMT, I'd want it to be all SMT and bite the whole bullet.
mcop
PostPosted: Thu Oct 11, 2012 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I guess I'd better not be such a wimp and go for the SMT chips as well Smile I've been soldering since the late 80's so I should really b up to the task!
Audio files: 22
PostPosted: Thu Oct 11, 2012 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Well I guess I'd better not be such a wimp and go for the SMT chips as well I've been soldering since the late 80's so I should really b up to the task!
Oh your not alone really. I was in the same situation until finally about 4 years ago I had to learn how to solder the SMT hardware since many chips I use are not even in DIP or easy to solder packages. I ended up getting SMT training kits with dummy components, so to not destroy perfectly good components, and watched lots of training videos online. Finally, I practiced and learned. Very Happy
Bill
PostPosted: Sun Oct 14, 2012 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
go for SMT.
0805 and soic is really no problem at all! and you can mix it with TH as necessary anyways.
fonitronik at
Audio files: 22
PostPosted: Sun Oct 14, 2012 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I agree Matthias. I would say that 0805 sized passives and SOIC are probably the best for SMT starters AND they make circuit boards very compact by putting components on both sides. The are more affordable when getting manufactured additionally.
Bill
Moogah
PostPosted: Sat Oct 20, 2012 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in 2-4 voices of this.
Jojjelito
PostPosted: Sun Oct 21, 2012 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd be interested in 2x quad boards. I don't mind SMT at all, works just as well for my soldering setup.
Audio files: 22
PostPosted: Sun Oct 21, 2012 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK a few more, that's cool ....
Cool
Bill
captainhaha
PostPosted: Sun Oct 21, 2012 7:04 pm    Post subject: Quad Bass++ please Reply with quote  Mark this post and the followings unread
I'd be interested(interested enough to register:) in buying either a 1x4 or 2x2 board. SMT might be a laugh, why not?
C
catchpenny
PostPosted: Fri Oct 26, 2012 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm just getting started in DIY but am interested in this. in either 1x2 or 1x4 - whichever really. I'd like to do it Euro format though I'm a little scared of this talk of SMT.
So cautious interest registered I guess?
Audio files: 22
PostPosted: Sat Oct 27, 2012 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok guys, thanks for more of your feedback. I will keep this going for a bit Longer and then make my decision.
Useemu
PostPosted: Tue Oct 30, 2012 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take two.
mcop
PostPosted: Tue Oct 30, 2012 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Having now had a go at SMT soldering I'm more than happy with 0805 sized passives. A fine tip on your iron and a pair of reverse grip bent nosed tweezers and it's really quite easy.
HansRL
PostPosted: Mon Nov 19, 2012 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I already have all the bits needed for a build like this in my parts bin. None of them are SMD thought. I guess finding the LM13700 as SMD will limit the list of usual sources quite a bit. Builders outside US might prefer if there where a component kit available to them if this is happening with SMD. I know that this is the path I would have to take.
just my 2 cent
Audio files: 22
PostPosted: Mon Nov 19, 2012 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hans
Thanks for your input. I will no doubt source parts for it. This makes it much easier, quicker, and less costly .
Bill
Audio files: 22
PostPosted: Thu Dec 20, 2012 5:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Guys, I kept this going for a while and it looks like a fairly underwhelming response thus the Quad Bass++ is officially a dead project. I am sorry guys as these boards are getting more expensive to get manuafactured and with only two or three interested, it's a no brainer. I thank those who did respond.
Happy and healthy holidays to all !!
Bill
HansRL
PostPosted: Thu Dec 20, 2012 6:52 am    Post subject: QB++ vs MPS Reply with quote  Mark this post and the followings unread
Thanks for the update Bill.
I've got one board for the MPS I plan to build this winter.
How does the MPS compare to Bass++ ?
The few demos I've found on the net it looks like it's very easy to go wild with all the controls on the MPS. And not actually ending up with a drum sound. Although that can be very creative it could also be very annoying trying to get drum sounds from 4 channels.
...asking course the MPS board are still available her at EM.
mcop
PostPosted: Thu Dec 20, 2012 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
No worries and totally understandable. Knocked up a stripboard layout a while ago and will put one together when I have time. To many other things on the go at the moment anyway. I can always lay out a pcb myself in the future if I need to.
emSynth
