garcho
Posted: Tue Oct 09, 2012 9:16 pm Post subject:
5 Note Lunetta |
Howdy y'all, I've been noodling on the breadboard and drew this up so I thought I'd post here. It's a very slightly sexed-up Schmitt trigger. 5 keys, 5 knobs, 5 switches. In the process of building one, have a PCB in the tank now. Lots of fun sounds, will post some samples soon, along with some pics and PCB stuff. All suggestions welcome!
 _________________ "The life of a repo man is always intense." |
Audio files: 254
Posted: Wed Oct 10, 2012 10:30 am Post subject:
thanks for posting, looks interesting
I'm currently doing some vactrolled oscillator stuff myself, and I can get very nice sounds out of it, so would love to
hear some sound samples from this design.
one thing that doesn't seem right to me is how you connected U1D, U1E, U1F. assuming these are just spares and
not meant to heat your tea/coffee/soup or whatever you want to keep warm, I would only connect the inputs
to GND not the outputs
or just make more oscillators out of them = more fun  _________________ "My perf, it's full of holes!"
http://www.acidtrash.com/ |
garcho
Posted: Wed Oct 10, 2012 3:33 pm Post subject:
| Quote: | | only connect the inputs to GND not the outputs |
thanks for the extra eyes!
can you believe there's 6 oscillators on this little 1c chip?!?! I'm trying to keep the hardware part count down, so I'll probably finish building this with only 3. _________________ "The life of a repo man is always intense." |
analog_backlash
Joined: Sep 04, 2012 Posts: 244 Location: Aldershot UK
Posted: Thu Oct 11, 2012 4:43 pm Post subject:
An intriguing circuit - I've just been thinking about how it all works. I nearly sent you a very stupid reply, but then I realised that I was mis-reading the circuit diagram (when your interconnecting lines cross, they are connections, I think). That's where the little blobs come in handy.
I'm looking at the capacitor values attached to your keyboard. Is there any clever plan to this, i.e. are the keys in any kind of musical interval apart? Probably, a silly question for a Lunetta thread... Also, where did you geta 1u33 capacitor (or is it a 1uF in parallel with a 330nF)? I've never seen one with that value before.
Look forward to hearing the results,
Gary |
garcho
Posted: Thu Oct 11, 2012 8:44 pm Post subject:
| Quote: | | when your interconnecting lines cross, they are connections, I think |
yes! every intersection is a physical one. this is how U1C becomes an oscillator, for instance.
| Quote: | | I'm looking at the capacitor values attached to your keyboard. Is there any clever plan to this, i.e. are the keys in any kind of musical interval apart? |
yes! and what a moron I am for not posting those notes. this arrangement creates a pentatonic scale, for instance, depending on the 'pitch' resistance, the scale would be G A C D E. I arrived at the capacitor values by ear, not by calculator. Quicker for a ignoramus like myself...
| Quote: | | where did you get a 1u33 capacitor? |
...which is how I ended up with 1u33 as a value. I used a 1u with a 330N in parallel, like you mentioned. I'm sure there's a smarter way to get the same ratios with more common values, but I was happy enough with this.
| Quote: | | Look forward to hearing the results |
I just finished populating the PCB and it works just like the breadboard! I'll post the print image along with the corrected schematic and some video/audio soon, after I stuff the enclosure, maybe a week or so, depending on real life.  _________________ "The life of a repo man is always intense." |
analog_backlash
Posted: Fri Oct 12, 2012 12:36 am Post subject:
Ah! I thought that it might be a pentatonic scale ( the word Pentasonic in your title is a bit of a clue...). That also explains the strange capacitor value. I think that putting the 2 caps in parallel is a perfectly valid way of achieving this.
Thanks for the clairifications,
Gary |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Fri Oct 12, 2012 9:29 am Post subject:
Cool circuit. Thanks for posting.
Just a suggestion. Don't ground unused outputs in CMOS chips, unless you know that the output will be LOW because of the way you have tied the inputs. This will be an unnecessary current suck.  _________________ --Howard
my music and other stuff |
garcho
Posted: Fri Oct 12, 2012 9:52 am Post subject:
Thanks for the tips and kind words! Any advice for how I should deal with the unused inputs in this instance? _________________ "The life of a repo man is always intense." |
trav
Audio files: 9
Posted: Fri Oct 12, 2012 2:39 pm Post subject:
| tie unused inputs to ground, leave unused outputs hanging |
garcho
Posted: Fri Oct 12, 2012 6:02 pm Post subject:
Oh, that's what I thought. Messed up the schemo then misread Mosc's post. Gotta slow down!  _________________ "The life of a repo man is always intense." |
Audio files: 107
Posted: Sat Oct 13, 2012 10:01 am Post subject:
Yes, Trav got it right.
[didactic and not necessarily directed at garcho]
CMOS is said to use virtually no current, which is almost true. It uses current only during the transitions from high to low or vice-verse. This is because CMOS inputs have almost infinite input resistance and very small input capacitance. For practical purposes, the only current CMOS uses to to pump up or pull down the capacitance of the gate inputs. Once these capacitances are charged up or pulled down, no more current is used. But when an output is tied to the state opposite to the logic of the inputs, you get a switch which will draw the max possible current constantly. The amount of this current is limited by the dimensions and materials of the internal transistors.
Lunetta circuits, which run at very slow audio and sub-audio rates, use very little current. Crank the clocks up a few hundred times and those chips would get too hot to touch and would eventually burn up if there are enough gates that are switching in the chip. This probably won't happen in a hex-inverter though. Still saving power one place give more to use elsewhere.
At one time I used to design CMOS DSP chips.
[/didactic] _________________ --Howard
garcho
Posted: Sat Oct 13, 2012 11:02 am Post subject:
Thanks! Makes a lot of sense. _________________ "The life of a repo man is always intense." |
garcho
Posted: Sun Oct 14, 2012 12:15 pm Post subject:
| Quote: | | [didactic and not necessarily directed at garcho] |
I just want to add that the 2 reasons I visit this site are 1: to learn absolute basics; and 2: inspiration; so I hope folks like mosc don't feel like they have to tiptoe around the egos of hacks like me.  _________________ "The life of a repo man is always intense." |
