 Forum index » Instruments and Equipment » Waldorf
Blofeld with low output and no phones
Page 1 of 1 [17 Posts]
my05
PostPosted: Tue Sep 13, 2011 2:52 am    Post subject: Blofeld with low output and no phones
Subject description: low volume / no volume
I recently acquired a Blofeld with the above problems. I have tried to contact Waldorf (no answer yet) regarding this as i have also searched the net and found other people with similar problems.
Some people claim that the problems started when they upgraded the firmware to 1.15, some other people have had this problem since earlier FW versions.
When trying to find more details, some search-hits points to either a broken transistor or the op-amps that drives the line and phone jacks. What usually "breaks" on the Blofeld?
regards
Daniel
PostPosted: Tue Sep 13, 2011 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
You might just have a bad output socket. Smile
ACHTUNG!
my05
PostPosted: Tue Sep 13, 2011 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I assume that would be possible, but there is sound coming from the line outs (low, but still). When i crank the mixer up, the sound is chrystal clean without glitches or any other bad things). I've heard that the Blofeld output volume is low, but not this low.
I will take the Blofeld apart and start to measure in/out signals on the two op-amps.
(apparently a LM1877 for the head-phones and a NE5532 for the line outs)
PostPosted: Tue Sep 13, 2011 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
HOw much noise is present on the output?
It may be that the Blofeld has a really wide dynamic range. I had the same problem with this with my old Yamaha AN1x.
It's something I need to check with my own Blofeld. I still havent had the time to play with it. Embarassed Sad
ACHTUNG!
my05
PostPosted: Tue Sep 13, 2011 9:22 am    Post subject: Reply with quote  Mark this post and the followings unread
No noise at all tbh. I guess it was not supposed to leave THAT much headroom either ( Wink) since i really need to adjust both the volume and gain to the max to get a normal (clean) signal from it.
If you would have the time to check your Blofeld, i would really appreciate to hear your opinion regarding the the output.
regards
Daniel
PostPosted: Tue Sep 13, 2011 10:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Now there's a really good excuse to plug mine in! Smile
I'll try tomorrow.
ACHTUNG!
my05
PostPosted: Tue Sep 13, 2011 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Appreciate it Smile
my05
PostPosted: Wed Sep 14, 2011 2:14 am    Post subject: Update - What probably causes this Reply with quote  Mark this post and the followings unread
After getting in touch with another Blofeld owner/electro engineer and getting some indirect information from Waldorf, i now can assume that the resistor sitting between the psu and the op-amps is to blame.
Apparently, this resistor (6.8 ohm, 1/4 watt SMD) is also used as a fuse to protect the hardware and when it blows, the result is just like this (i.e low/no sound).
PostPosted: Wed Sep 14, 2011 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
That's good to know.
Thanks Daniel! Smile
ACHTUNG!
dougt
PostPosted: Tue Oct 02, 2012 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Same thing happened to me. Can you tell me the board location of that resistor? Is it the one by itself between the Shift button and Mix 1 pot?
Thanks
http://www.synthparts.com
dougt
PostPosted: Mon Oct 15, 2012 3:14 am    Post subject: Reply with quote  Mark this post and the followings unread
OK so I replaced that resistor and it's working fine again. For future reference for anyone else who might encounter this problem it is the resistor located between the Shift button and the Mix 1 pot.
wishniak
PostPosted: Thu Feb 21, 2013 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm - glad to find this post - just picked up a blofeld and it seems to have this problem too. anyone else made this repair? know of the top of their head the value of the resistor (before i crack this thing open?). thanks..
wishniak
PostPosted: Mon Feb 25, 2013 6:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
ooops - finally re-read and realized my thread reading comprehension sucks sometimes.
but ouch SMD... anyone tried this to any success?
dougt
PostPosted: Tue Feb 26, 2013 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes I used a regular sized resistor...
Paradigm X
PostPosted: Tue Feb 26, 2013 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks all ... mine was a bit quiet when i got it (free!) and seems to have got worse.
ill have a look
cheers
Ben
urbanspaceman
PostPosted: Tue Feb 26, 2013 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a fix on the net for this problem (and other)
http://www.noisecollective.net/media/kunena/attachments/579/blofeld_low_output_repair.pdf
check my thread (italian) about this.
http://www.noisecollective.net/forums.html/nc-forum/sintetizzatori-virtualanalog/162-qualche-risorsa-per-il-blofeld#792
Urban
Paradigm X
PostPosted: Wed Feb 27, 2013 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much Urban
Smile
