DC Mixer /Glide /Dual VCA (Stripboard)
Page 1 of 1 [6 Posts]
vladosh
Audio files: 46
PostPosted: Thu Oct 18, 2012 4:45 am    Post subject: DC Mixer /Glide /Dual VCA (Stripboard) Reply with quote  Mark this post and the followings unread
Figured i need another mixer so this one is 8 ch ,or 2 x 4 ,the wiring i have in mind is bit different but anyhow one can make use of this as it is ,the glide is there to make fade in/out control of one of the vca's ..just for testing ,for that purpose you need a switch / momentary with positive / ground going into the lag processor and then into one of the vca's ,there was no room for two lags on this piece of reused stripboard ,i haven't built it yet but will start soldering anytime really ,,here are the links for the schematics used in this layout
the vca modules : http://yusynth.net/Projects/Wildcat/vca-modules.html
the lag : http://www5b.biglobe.ne.jp/~houshu/synth/Glide0301.GIF
the dc mixer : http://www.sdiy.org/ensign/7.jpg
(uploaded new version) x3
thanks Phobos ,found it Smile
 Filesize:  258.79 KB
 Viewed:  334 Time(s)
Audio files: 705
PostPosted: Thu Oct 18, 2012 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't check if the layout is correct compared to the schematics. but you do have a bad short in the current layout Wink
(or at least that's what it looks like to me)
Audio files: 705
PostPosted: Thu Oct 18, 2012 7:34 am    Post subject: Re: DC Mixer /Glide /Dual VCA (Stripboard) Reply with quote  Mark this post and the followings unread
yeah, that looks right Smile
AlasdairMoons
PostPosted: Thu Nov 01, 2012 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
nice layout => I think I have to move from PCB to stripboarding Smile
my Music-Channel:
my Facebook:
vladosh
Audio files: 46
PostPosted: Thu Nov 01, 2012 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Sasha Smile
synthesist
PostPosted: Tue Mar 19, 2013 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
can someone tell me if the VCA is usefull to switch control voltages?
Cause I am searching for a simple VCA design that could switch LFOs but also some audio oscillators for sick frequency modulation.
Xonrad
