 Forum index » Instruments and Equipment » Waldorf
MicroQ Modulation Wheel Issue
Page 1 of 1 [2 Posts]
zaxmalloy
PostPosted: Tue Oct 02, 2012 10:25 pm    Post subject: MicroQ Modulation Wheel Issue Reply with quote  Mark this post and the followings unread
Just picked up a MicroQ Rack (Yellow) and it does not seem to be able to receive Mod Wheel messages. Latest OS 2.22 is installed.
Nothing seems obviously amiss and the unit otherwise performs flawlessly. My Axiom controller seems to be sending mod wheel messages fine to other units. Pitch bend works without a hitch.
Any ideas?
namnibor
PostPosted: Sat Oct 20, 2012 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I have an Axiom Pro 61 so do not know if this will help any but will ask if you perhaps previous owner has midi cc 1 value settings at 0 instead of typical range of 1-127? Conversely, on your Axiom, do you have that "scene" or "template" midi cc1 for modulation wheel set with no range at all? By default should effect filter and resonance, etc. but sounds like it *possibly* could be one or both of suggested things to check out. Also, is both your Axiom and Micro Q set the same midi channel or global? Could microQ be in Multi-Mode rather than Play/Single? You never know what you may inherit in what previous owner had for settings and of course the manual for O.S. 2.22 is on Waldorf.de under legacy hardware>microQ>Documentation. Hope this points in direction to solve this and cannot recall if you said that all other programs/banks also only do not respond to mod wheel, if not, it sounds like just a setting issue with your hardware.
Sonic Arsenal: Waldorf: Blofeld Black Kbd, MicroQ Omega, Yellow MicroQ, Microwave XT, Q-Rack, Miniworks 4-Pole; Access Virus KB and KC; DSI Evolver Desktop and Mono Evolver Keyboard (poly-chained)-x2; Korg: Radias Kbd, Wavestation SR, Kontrol 49; Alesis: Ion, QS8 as excellent 88 weighted multi-zone midi controller, Fusion--for HollowSun SampleBanks; Novation Supernova 1, SL MK II 61; Roland SH-32; Yamaha: RM1X, CS2X, Reaper, Fast Track C600, Studio Maine Coone Cat pre-loaded with wavetables on each fang!
Niio1
