Thomas Henry XR VCO
Page 1 of 1 [9 Posts]
crashlander42
PostPosted: Fri Feb 02, 2007 9:03 pm    Post subject: Thomas Henry XR VCO
Subject description: A couple of stupid questions.
I'm working on my XR VCO and noticed that orientation of the electrolytic caps isn't marked on the parts placement diagram. I'm sure I'm missing something stupid. I also noticed the .22uf cap (CCool isn't on the parts placement. I'm sure the solution is obvious. Those solutions are the ones I'm most likely to miss. Smile
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
Scott Stites
Audio files: 96
PostPosted: Fri Feb 02, 2007 10:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not stupid questions at all.
I've attached a JPG showing where the positive leads of C11 and C12 go.
C8, I believe, is attached directly between J3 and R35 (the linear FM input attenuator).
Have you checked out the BugBrand layout?
Scott
 Filesize:  38.16 KB
 Viewed:  2227 Time(s)
Scott Stites
Audio files: 96
PostPosted: Fri Feb 02, 2007 10:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, yes, C9 and C10 also!
 Filesize:  46.19 KB
 Viewed:  2217 Time(s)
crashlander42
PostPosted: Fri Feb 02, 2007 10:37 pm    Post subject: cap orientation Reply with quote  Mark this post and the followings unread
Thanks for your help!
Any idea about c13? Smile Just that one one and I'll leave you alone.
My DIY stuff Flickr
Scott Stites
Audio files: 96
PostPosted: Fri Feb 02, 2007 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
AS Homer Simpson is wont to exclaim: "Doh".
Pictured below.
Scott
 Filesize:  23.3 KB
 Viewed:  3722 Time(s)
chonald
PostPosted: Sun Feb 04, 2007 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm having this same problem, but with the Bug Brand pcb layout.
Would anyone know about the orientations of the caps in that one?
Also, doesn't the Bug Brand pcb have an extra cap to turn it to a low speed? Where is this, and how is it connect?
Cole
bugbrand
PostPosted: Mon Feb 05, 2007 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hiya Cole
Aye, I should have marked it on the pdf.. no time right now I'm afraid, but you can print the pdf and pretty easily figure which way around any polarized caps go. C7x is the cap for lfo - experiment.. something like 4u7 - maybe try a non-polarised cap. Experiment.!.
http://www.bugbrand.co.uk
Fernando
PostPosted: Wed Feb 07, 2007 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi all, is there a pcb available from somewhere? (or amybe a spare from any of you?)
stahlblau
PostPosted: Mon Oct 22, 2012 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott
i'm just building the xr vco and have the same questions. Unfortunately the attachment isn't available anymore. Can someone help me please?
I wonder where to put c8, r7... Question
Many thanks
André
JuneSolstice2013
