2012 Build Pictures
Page 13 of 16 [383 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13, 14, 15, 16 Next
dougseidel
PostPosted: Thu Sep 20, 2012 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - these are slotted shaft pots (1/4") - so the knobs just have a whole drilled part way through, and the knobs are held with friction.
For plain shafts, i put a small machine screw through the side of the knob (pre drill) to attach the knob to the shaft.
glass and ceramic knobs are hard to attach - i don't have a good way...
http://dougseidel/tumblr.com
sduck
PostPosted: Sat Sep 29, 2012 5:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it still 2012? If so, then I built this -
Synthesis Technology e560 front
Synthesis Technology e560 profile
Synthesis Technology e560 back A
Note the stick-on paper label for the lower switch - ultra-hi-tech solution to the rescue! I had either forgotten about this option jumper, or had decided not to add it for this one, but after getting the panel decided I actually wanted it.
cloudscapes
PostPosted: Sun Sep 30, 2012 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
not exactly synth, but not strictly guitar either Very Happy
http://www.youtube.com/watch?v=JdqwXGB0944
also featuring an OP-1
Sonic Crayon DIY effects lab
dougseidel
PostPosted: Tue Oct 02, 2012 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
An ultrasonic generator (35 - 45 kHz) for use with a feedback setup, including goofy battery access lid thing. RCA output on the other side.
 Filesize:  220.19 KB
 Viewed:  73 Time(s)
Audio files: 107
PostPosted: Tue Oct 02, 2012 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
dougseidel wrote:
An ultrasonic generator...
Don't put that in your carry-on on your next flight. Smile
egasimus
PostPosted: Sat Oct 06, 2012 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Boogdish wrote:
The sound quality from my camera is TERRIBLE, but this module only does control signals.
This is a prototype I finished yesterday, it's a voltage to rhythm converter. It does an ADC on an input voltage and uses the binary result as an 8 beat pattern. 8 different outputs can each correspond to a different sample, or it can be put in parallel mode and each output corresponds to a certain bit of the same sample. It can output triggers or gates, has a built in clock or can run off an external clock. I've had a lot of fun with it over the last couple of days!
GENIUS!!! Smile
egasimus
PostPosted: Sat Oct 06, 2012 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Also, what's with the credit card thing?
PostPosted: Sun Oct 07, 2012 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boogdish wrote:
...It does an ADC on an input voltage and uses the binary result as an 8 beat pattern....
that's exactly what my VCPS-8 / mh11 ADC Sequencer does! and it's true, it is absolute fun: 256 different patterns accessible by control voltage.
in my experience it works best with another sequencer running on the divided clock...
(and the 8 single outputs are planned as a expansion module connected via a ribbon cable to the main sequencer)
fonitronik mh11 ADC Sequencer (1st impressions) from fonitronik on Vimeo.
fonitronik at
Boogdish
PostPosted: Sun Oct 07, 2012 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great minds think alike!
PostPosted: Mon Oct 08, 2012 12:34 am    Post subject: Reply with quote  Mark this post and the followings unread
alas, i sold not that many PCBs for DIY in May 2010, and there was never enough interest to do a 2nd run for these DIY PCBs since then!?
anyways, this module will be released soon as pre-built eurorack module, hoping enough people will dig the idea...
fonitronik at
Audio files: 69
PostPosted: Sun Oct 14, 2012 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
Here's the story so far; Suitcase Synth and the Behemoth. Just a few more modules to go...
Hey Rich , that's a fantastic looking modular , very nice instrument , good work.
www.myspace.com/skrogproductions
Audio files: 69
PostPosted: Sun Oct 14, 2012 6:25 am    Post subject: Re: WogglebugXL Reply with quote  Mark this post and the followings unread
..,and yesterday I finished my WogglebugXL Very Happy It's based on Richard Brewster's version, with some extra in- & outputs
and adjusted to -5/+5V levels, except for the clk rate CV, which is now buggin me a bit (you get it 'buggin' , sorry that was really bad)
so i'll probably change that sometime.
Simply AMAZING ! , fantastic front panel art , Smile
dave_3283
PostPosted: Wed Oct 17, 2012 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Finally building after quitting in frustration (and also because I got married) 4 years ago. First two done:
 Filesize:  259.58 KB
 Viewed:  63 Time(s)
PostPosted: Wed Oct 17, 2012 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
party time!
fonitronik at
fluxmonkey
PostPosted: Thu Oct 18, 2012 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd like to think that Louis and Bebe wd approve...
 Filesize:  60.81 KB
 Viewed:  63 Time(s)
www.fluxmonkey.com
emdot_ambient
PostPosted: Thu Oct 18, 2012 2:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Audio or video demos or it didn't happen!
Seriously, is that a CGS Real Ring Modulator board? Clever way to mount some seriously big transformers! afro
PostPosted: Sun Oct 21, 2012 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Whoa! Those are huge transformers, fluxmonkey! Is there any advantage or difference in the sound? I made a passive ring mod several years ago with the miniature ones and fit it easily in this tin...
James.
P.S. "Gourmet powder" is code for M.S.G. (didn't eat it, just dumped it)
P.P.S. Sorry for posting a photo of a build not done in 2012.
 Filesize:  76.44 KB
 Viewed:  3971 Time(s)
Psyingo
PostPosted: Tue Oct 23, 2012 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is a build i finished recently. I call it the CDS-1, for compact drone synth. I used this name a long time ago to denote 'CMOS Drone Synth' but the design has changed heavily, and the original CDS-1 is only in my possesion, so i can call it wahtever i want to call it.
im going to be selling this on ebay, as i need money desperately.
and here is a video
-minus-
PostPosted: Wed Oct 24, 2012 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey well done for selling this Psyingo! I'm really pleased for you. It's a nice sounding unit!
well done party time! well done
PostPosted: Wed Oct 24, 2012 10:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Still in progress, and this is just a mock up panel to test with, but here's a Soundlab I'm working on....
 Filesize:  476.6 KB
 Viewed:  61 Time(s)
 Filesize:  416.58 KB
 Viewed:  51 Time(s)
Audio files: 261
PostPosted: Thu Oct 25, 2012 6:48 am    Post subject: Reply with quote  Mark this post and the followings unread
looks like a box of fun to me Very Happy
nice case!
http://www.acidtrash.com/
sduck
PostPosted: Thu Oct 25, 2012 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
You may think you're in some sort of time loop, and yes, maybe you are. But... I did post something very similar to this way back at the top of this page. This is the e580 version, in a mirror image panel design, so that if they're next to each other in my modular cabinet, they cancel out. Or something like that.
MOTM e580 front
MOTM e580 front
KRS1972
PostPosted: Fri Oct 26, 2012 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Here are pictures of my 19" eurorack cabinet.
Space for 8 eurorack units and 2 aluminium front plates (6HE)
Grt,
Chris
 Filesize:  1.11 MB
 Viewed:  51 Time(s)
 Filesize:  1.29 MB
 Viewed:  53 Time(s)
 Filesize:  1.23 MB
 Viewed:  52 Time(s)
 Filesize:  954.23 KB
 Viewed:  52 Time(s)
PostPosted: Sat Oct 27, 2012 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
that looks really great!
you are used to do woodworks, don't you? and you have a nice workshop!
fonitronik at
PostPosted: Tue Oct 30, 2012 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
My first aluminum panel. For a utility module, so if I had screwed it up, I could go ahead with it anyway. But I think it turned out pretty well...it's going to take some practice to get my rows perfect, but there's nothing that jumps up and screams WRONG, so I'm very happy with it.
The boards (not yet mounted, might be a challenge given the density Smile ) are based on MFOS CV and Gate Distribution: http://www.musicfromouterspace.com/analogsynth_new/CVANDGATEDIST/pdf/schematic_pg1_schem.pdf And some other stuff I can't find again for doing sum and difference (at least partly on Forrest M Mims Op Amp Notebook).
 Filesize:  447.16 KB
 Viewed:  56 Time(s)
emSynth
