smokestacksproductions
Posted: Fri Aug 24, 2012 8:23 am Post subject:
YUSYNTH VCO strange startup behavior Subject description: I have to momentarily short out the negative rail to get the VCO to work |
Hello,
I recently completed a YUSYNTH VCO. When I turn on my system, the VCO does not work, I measure less than 1 volt on the pins that should be -14.3.
If I short out the negative rail momentarily it comes to life and I can use it regularly for the rest of my session.
What could be causing this? Is it the 7915? Or a bad Capacitor? |
Sebo
Posted: Fri Aug 24, 2012 1:00 pm Post subject:
| Thanks Sebo, I'll try this and get back to you. |
Sebo
Posted: Fri Sep 28, 2012 8:12 am Post subject:
| I built another one of these modules, this time I made the lm394 version. I get the same strange behavior. After more investigation I learned that it works fine if I apply power to the positve rail first, and then the negative rail. I have not had problems with any other modules, I am using a power supply that I built which is based on the standard 7815/7915 circuit with center tapped transformer. Can anyone offer some idea as to why this is happening? |
prgdeltablues
Posted: Fri Sep 28, 2012 8:37 am Post subject:
Yes, it's a known problem with negative voltage regulators (some, not all, perhaps certain brands). Goggle latch up.
Peter |
Sebo
Posted: Fri Sep 28, 2012 1:03 pm Post subject:
I replaced the 7915L on the firts VCO like you suggested, but the problem remained. I first used a generic "multicomp" brand, and then replaced it with one from NTE which still did not work.
Can you reccomend a known good brand or part number please?
What about adding extra diodes to prevent "latch-up" ? |
Sebo
Posted: Fri Sep 28, 2012 1:49 pm Post subject:
That's ok,
I really appreciate your help with this. I will try to order some different ones soon.
Thanks! |
Cardinen
Posted: Sat Sep 29, 2012 6:44 am Post subject:
Yes, is a common problem sometimes with some brands of 78xx/79xx.
I suggest to use regulators from ST or Fairchild, never had a problem with these.
Anyway you can try a schottky diode or germanium (i've used 1N5819 with success for preventing latch-up).
Another method could be add a small resistance in series with the negative regulator, so the negative rail will delay up a bit so the positive rail can start without latch-up.
Usually latching problems comes when there are rail-to-rail decoupling caps. |
yusynth
Posted: Mon Oct 01, 2012 6:24 am Post subject:
I have question what power supply are you using ? Have you tried with another PSU ? _________________ Yves |
Pilastik
Posted: Fri Oct 26, 2012 10:03 am Post subject:
| I have the same latch up issues with the regulators. Definitely the Motorola ones don’t work, some only after shorting out the negative rail. Is there any recalculation on the resistor values to power the vco without the 78L../79L.. ones? |
Posted: Fri Oct 26, 2012 2:16 pm Post subject:
| The regulators are there to provide a reference voltage of 14.2v (this is what you get after voltage drop) so use that figure when you calculate |
Sebo
Pilastik
Posted: Fri Oct 26, 2012 9:36 pm Post subject:
| Yes I know that and when it works is amazing and very stable (LM394 version). I’ll try to find some ST regulators… |
ranioItaly
Posted: Mon Feb 18, 2013 9:29 am Post subject:
same problem with 78L15 |
hallo, I am new in this forum, I have built a VCO but at first time the 78L15 puts out less than 1v.
I try to change it with other brand but it is the same.
I read from Cardinen post the possibilty to add a resistor or diode.
Can somebody post the schematic for this modifies?
Many thanks |
Sebo
ranioItaly
Posted: Tue Feb 19, 2013 8:02 am Post subject:
thank you for your answer Sebo, but I have missed to tell: if I switch down the power supply twice or three times the 14,2 volt appears and the VCO works normally.
I think the 15Volt (measured with voltmeter) on input of 78L15 isn't enought for start it.
I would try to insert a big value resistor, or a diode, between input and output of 78L15 for put high the 14,2 volt at start-up , but I prefer ask to the user of this forum if is a wrong idea. |
marvkaye
Posted: Tue Feb 19, 2013 8:20 am Post subject:
The 78L15 needs at least 16.7 input volts for reliable regulation. It would prefer 17.5. See the data sheet.
<marv> |
ranioItaly
Posted: Tue Feb 19, 2013 8:53 am Post subject:
Hi Marv, thank you.
I understand what you mean, but the Yusynth VCO wants +15v/-15v for supply the board and inside it has one 78L15 and one 79L15 for increasing stability. these is the original schematic and should works fine. |
marvkaye
Posted: Tue Feb 19, 2013 9:34 am Post subject:
I see what you mean. I read Yves notes regarding them on his website... looks like the 14.2v is crucial to the design. It'll be interesting to hear how you get to the bottom of your issue...
<Marv> |
