  Special Sunday Episode with Twyndyllyngs Chez Mosc
Another completed SoundLab! (pics included)
Page 1 of 1 [11 Posts]
cds56
PostPosted: Thu Nov 08, 2012 7:21 pm    Post subject: Another completed SoundLab! (pics included)
Subject description: Finally furnished my minisynth!!
I started building my minisynth in December 2010(I believe). I populated the PCB, and... well wait one second.
Ray in the kit you sent me you left out ONE cap! a single ceramic cap of a common value which I had, but still. that's a single issue with it.
So I got busy around that time so let's say around 9 months later I cut a crude faceplate from a new aluminum cookie sheet, drill it out, and wire the whole thing based on Ray's schems and faceplate layouts Smile (so easy)
I measured and cut out the box but never assembled it. It was left housed in an old shoebox.
until last weeekend where I did it all in a 36 hour time period !!
Note: as of late, the noise generator has become plagued with immense oscillator 2 bleedthrough and noise that doesn't sound anything like noise!
TL; DR I took two years to do a two week or less project because lazy. am satisfied !
imgur: http://misteralien.imgur.com/all/
PostPosted: Thu Nov 08, 2012 11:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had a lot of trouble with bleed into the noise; I used the "optional improvements" noise circuit and it went away.
My build's not done yet though Very Happy
Edit: PS your images are not publicly accessiable Smile
ashleym
PostPosted: Fri Nov 09, 2012 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought the finished synth was just a little.........erm.......dark
http://www.youtube.com/watch?v=wj84tfS7ag4
cds56
PostPosted: Fri Nov 09, 2012 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Whoops, I couldnt figure out how to link directly to the album which was public, okay everything is viewable now I hope...
here:
http://imgur.com/a/K3v85
The faceplate needs trimming, and I should takea look at the optional improvement noise circuit...
PostPosted: Fri Nov 09, 2012 9:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, was able to see it now. Thanks!
cds56
PostPosted: Sat Nov 17, 2012 12:44 pm    Post subject: help Reply with quote  Mark this post and the followings unread
well apart from the noise gen, I found a little quirk..
When I tap the solder joint for a resistor on the right-top side of the pcb with my finger, it triggers a gate.
What does this mean? my finger is not shorting out any of the other connections..
http://www.youtube.com/watch?v=5ScqhTyZ1i0
Audio files: 219
G2 patch files: 319
PostPosted: Sat Nov 17, 2012 1:03 pm    Post subject: Re: help Reply with quote  Mark this post and the followings unread
It probably means that you found a high impedance point there that you are injecting some hum into.
cds56
PostPosted: Sat Nov 17, 2012 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
would the answer to that be "Stop touching your PCB while the synth is turned on"?
I guess that could make.. sense..
Audio files: 219
G2 patch files: 319
PostPosted: Sat Nov 17, 2012 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or don't stop - it won't kill anything likely Wink
bubzy
Audio files: 63
PostPosted: Fri Nov 23, 2012 2:15 am    Post subject: Re: help Reply with quote  Mark this post and the followings unread
It means you have "trigger finger"
a common ailment amongst synth enthusiasts.
and what blue said.
_Richard_ Smile
cds56
PostPosted: Wed Dec 05, 2012 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Trigger finger! XD that's rather punny...
but I like it, guess I'll keep touching my synth in out of reach places Wink
