  Antimon Antimon Waves
MINICV
Page 1 of 1 [10 Posts]
El Mop
PostPosted: Tue Nov 06, 2012 10:59 am    Post subject: MINICV Reply with quote  Mark this post and the followings unread
Does somebody have experience with this?
http://www.midi-hardware.com/forums.html?section=prod_info&product=MINIcv
philoop
PostPosted: Tue Nov 06, 2012 12:23 pm    Post subject:  minicv
Subject description: minicv
i can recommand you MINICV i build 2 of them into my CS15 and worx fine
good support also
Deploying dual-wavelength fNIRS, we interrogate 16 locations in the forehead when eight able-bodied adults perform deception and truth-telling scenarios separately.
inlifeindeath
PostPosted: Tue Nov 06, 2012 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
i just finished mine and built it into a stand alone box. works great and highly recommended. videos here:
http://www.youtube.com/watch?v=XJDF8M5dQw0&feature=share&list=UUcAj7sBo6lOdzkvqhiXeQHg
http://www.youtube.com/watch?v=bD7CY5uzsys&feature=share&list=UUcAj7sBo6lOdzkvqhiXeQHg
El Mop
PostPosted: Wed Nov 07, 2012 2:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you at first.
I got a noob question:
The MINICV makes nearly perfect !V/Oct at 100K load. I build a synth based on the SLMS but with three oscillator. Each oscillators CV-input got a load of 100K. So I end up with 300K CV input.
Will this work, too? Or is there maybe thinking mistake by me?
El Mop
PostPosted: Thu Nov 08, 2012 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
To make my question a bit clearer.
Do I need a MINICV for each VCO or will one do it for all VCOs regardless of how much the synth has?
donpachi
PostPosted: Thu Nov 08, 2012 9:28 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as I understand, the MINICV is a single channel device. This means that you can only get one CV and one gate signal from it. However, you could apply the CV to all of your three VCOs (by means of a multiple). If the multiple is buffered, you do not need to worry about load; I think this is your concern if I understood correctly. By the way, if using a passive multiple, the load on the MINICV should be 100K/3 for three VCOs with 100K inputs.
If this is not what you want, you could get a multi-channel MIDI-to-CV device which has more CV and gate outputs.
El Mop
PostPosted: Thu Nov 08, 2012 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
That answered my question.
Thanks a lot!
alieneYe
PostPosted: Fri Nov 09, 2012 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
you could also build one of these voltage distributors then you would have no probs running 3 VCO with one CV drive
http://www.musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&PROJARG=OLDIESBUTGOODIES/VOLTAGEMIXER/voltagedist1.html&VPW=1426&VPH=622
El Mop
PostPosted: Fri Nov 09, 2012 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you!
The link doesn´t work but I found it on the MFOS-site.
Maybe you get the link working for the following guys that have that problem either.
alieneYe
PostPosted: Fri Nov 09, 2012 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
workin for me, but for those it is not working for, you'll just head to the synth-diy tab on mfos site, scroll down to MFOS oldies but goodies, and choose voltage distributor #1 or #2
i've built a few of #2 myself and they work great
