JAMESveeder
Posted: Fri Nov 09, 2012 9:37 pm Post subject:
Looking for a Lo-Fi Looper |
Hey guys, so I've been looking for a lower-fidelity looper schematic. The record time doesn't have to be long, I'm just looking for something really simple!
I tried the search feature but all of the threads contained .pch2 files for download, and I googled that and it said it was some sort of Nord synth file.
Anyways, does anyone know where I can find some schematics for something like this?
I'm trying to keep it reallly simple, for the fact that I'm a beginner and that I like lo-fi in general.
If there's a way to trigger it using a pulse or something along those lines, that would be INCREDIBLE, by the way.
Thanks, guys. |
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Sat Nov 10, 2012 4:50 am Post subject:
this is something ive been pondering for a while,
sometime ago i bought some APLUS voice recorder chips, they are ok, but a bit fiddly to use.
recently ive been learning (slowly) how to use the arduino for more interesiting projects and after some discussion with JovianPyx came up with the idea of using it as a mini sampler.
i haven't actually done anything with this idea at all, but the concept is fairly straightforward.
the audio signal comes into the arduino via the adc pins
it is then stored in an external eeprom (internal would work but is very limited)
the stored signal is played out via PWM on the digital pins.
Pros :
1) its easy to make, should be fairly straightforward coding
Cons :
*deep breath*
1)the ADC input is 10 bit, but the PWM out is only 8 bit
2)the PWM out is limited to a max of 62khz (and further limited by eeprom read/write(see 3)
3)the read/write rate of eeprom is fairly slow i cant remember exactly but you are probably not gonna get 11khz out of it.
4)its just an idea :p
im sure other people have found chips or some other way of doing it, this is just my input. _________________ _Richard_ |
ejr27233
JAMESveeder
Posted: Thu Nov 15, 2012 12:34 am Post subject:
bubzy, I just picked up an arduino, I have yet to play with it though. If it has the ability to do something like that, I'm definitely going to look into it. Unfortunately though, yeah, the arduino has very little memory...
I dont really know much about eeprom either. How is the learning curve for using all of this, do you think? It sounds like it may be a while before i get to anything close to this haha.
And I'm okay with Lo-Fi.
Are the APLUS voice recorder chips able to loop sound? I'm gonna see what I can find on these guys.
ejr27233, those kits may be a little too expensive for me.
I grabbed some of the greeting cards where you can record a message and play it back to try to circuit bend it, but nothing good came out of that really. |
Dougster
Joined: Sep 20, 2005 Posts: 272 Location: Tucson, AZ, USA
bubzy
Audio files: 64
Posted: Thu Nov 15, 2012 5:56 am Post subject:
learning curve is pretty good actually, if you have any sort of coding background, you can probably work most of what you need to do out in a day or two. eeprom is super simple too, all the libraries are written, a bit of copying and pasting and BOOM! you got reading and writing to an eeprom.
if i get a chance ill smash a quick demo program together and see if my concept works. (in work at the moment tho, so not now ) _________________ _Richard_ |
jaidee
Joined: Oct 28, 2007 Posts: 44 Location: Newcastle upon Tyne, UK
Posted: Fri Nov 23, 2012 4:33 am Post subject:
Go to madbeanpedals.com and check out the LoopHole lo-fi looper project in the Discontinued Projects section of the forum (you will probably have to sign up to get access but it's a great forum so go for it).
There is a circuit diagram and full PCB artwork.
You can find examples of completed builds in another section of the forum.
Its designed as a guitar pedal but otherwise seems to be exactly what you are looking for. |
