 Forum index » Clavia Nord Modular » Bugs
noises on G2X out with usb cable connected
Page 5 of 5 [115 Posts]
Goto page: Previous 1, 2, 3, 4, 5
dorremifasol
G2 patch files: 49
PostPosted: Fri Oct 07, 2011 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
mosc wrote:
Great suggestion, dorremifasol. Do you think you could post a picture to show how you do that?
Of course, here I go.
I've uploaded some pictures with descriptions. I've also attached an audio file with the recording of my G2 using the regular cable, and then the extension with the paper. I suppose most people don't notice the noise but keep in mind that I use headphones almost always and that way is very noticeable. Moreover, once you record the audio into a DAW and start compressing the buzziness gets really loud.
The record is just the G2 straight into my Fireface 800, without any other synth turned on.
Please keep in mind that I really don't know why it works. I thought it could work and tried disabling pins until it worked. Wink
You need the cable from the G2 to the PC, an USB extension cable, and a tiny bit of paper (probably thin plastic would be better).
 Filesize:  209.14 KB
 Viewed:  857 Time(s)
This is it!
 Filesize:  212.06 KB
 Viewed:  847 Time(s)
You have to put the paper exactly as it is shown in the picture.
 Filesize:  242.99 KB
 Viewed:  845 Time(s)
I like to keep the paper visible so I will remember this is a special USB connection, otherwise I may forget (bad memory here, really).
 Filesize:  230.91 KB
 Viewed:  814 Time(s)
noise.wav
Noise from the USB connection. First silence, then connection with the regular cable, next, disconnection, and lastly connection again with the "trick" enabled.
 Filename:  noise.wav
 Filesize:  2.16 MB
 Downloaded:  1356 Time(s)
Albert
dorremifasol
G2 patch files: 49
PostPosted: Tue Oct 11, 2011 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Now I know why it works. I'm disabling the +5 current pin, which is the one that carries the ground loop noise and it's not needed since the G2 has its own power source. I'm planning to disable every +5 USB pin not needed in my cables (ie. other synthesizers or devices that have their own power source).
Moreover, and I think this is very important: I know that the G2 does not need the +5v USB input pin (it's only used to provide power to some USB devices like mouses, keyboards, controllers, etc), but someway the pin IS connected to the synth board because the effects on the audio signal are very noticeable.
This leads me to think it shouldn't be that way. It may well cause the USB port to break if connected and disconnected very often, or if the computer sends a unusual voltage spike trough the +5v pin. You know there are many posts about broken USB ports in the forum.
What do you think about this?
Albert
Audio files: 211
PostPosted: Thu Oct 13, 2011 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for great post with all those pictures. Looks like a pretty easy trick to pull off.
Yes I think you're right. If the 5V is not needed in the synthesizer, then it should not be connected to any circuit.
The audio file shows a significant improvement.
Splendid...
Audio files: 275
PostPosted: Sun Nov 18, 2012 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've just done this and it works perfectly for me Smile
Thanks dorremifasol
dorremifasol
G2 patch files: 49
PostPosted: Sun Nov 18, 2012 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad to read that, Jez! Smile
Next time I open my G2 I'll see if can cut something somewhere to avoid using the cable thingie forever.
Albert
Audio files: 275
PostPosted: Sun Nov 18, 2012 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good luck with that Smile
chapelier fou
PostPosted: Tue Nov 17, 2020 4:55 am    Post subject: Reply with quote  Mark this post and the followings unread
First, thanks a lot for this topic.
I have similar problems and tried the "paper in the USB connector" approach.
For some reason, removing the connection to the +5V connector would not produce any result.
However, removing the Ground connection stops the noise. Hurray ? Is it safe ?
dorremifasol
G2 patch files: 49
PostPosted: Tue Nov 17, 2020 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi. Wow, I completely forgot about these pictures and the paper technique!
I wouldn't recommend doing that now. There is a much better and safe alternative, and that is using an USB Isolator. I have had one for years now and my G2 has worked beautifully since then, without any noise in my audio chain.
It was expensive when I bought mine (more than 60€ if I recall correctly) but nowadays they are much cheaper. It worths every cent and I feel more safe now.
This is the one I have:
https://www.olimex.com/Products/USB-Modules/USB-ISO/
Hope it helps!
Albert
chapelier fou
PostPosted: Tue Nov 17, 2020 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks for the super quick answer, I just bought this Olimex gadget, I'll see if it works.
dorremifasol
G2 patch files: 49
PostPosted: Tue Nov 17, 2020 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Great! Let us know how it goes.
Albert
Audio files: 211
PostPosted: Tue Nov 17, 2020 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree with Albert, but at the same time removing the ground is probably safe.
I'm not sure how household power is in Europe, but in the USA it can be the source of ground loop nightmares. I learned this from a wise old sound tech many years ago when setting up a huge live preformance system called the Electric Symphony Orchestra. We set up about 40 individual instrument amplifiers on the stage and when we turned it on there was horrible hum.
This old-timer looked at what was set up and said something like, "What idiots, you connect all the grounds together? What do people think these days?" Then he took about 1/2 hour going around with a wire cutter and removed the grounding pin on every single piece of equipment on the stage. When the prower was turned back on there was no hum.
In my studio nothing is grounded and I've never had any hum except for inheritly noisy synths like my 48 year old Moog Modular.
Still, I have never convinced anyone else to even consider massive ground removal. So, use a USB isolator, which removes the ground and power connections anyhow.
Hah, now I'm an old-timer.
chapelier fou
PostPosted: Wed Nov 18, 2020 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice. So my conclusion is : let this piece of paper until my USB isolator comes in the mail box !
I'll let you know how it works.
Anyway, it's a breathe, as I took the habit to edit the sounds with the headphones to avoid the noise, then disconnect USB for playing/recording.
jamos
G2 patch files: 41
PostPosted: Wed Nov 18, 2020 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
... he fixed the problem by vandalizing the equipment?
Had this old-timer never heard of a ground-lift plug?
chapelier fou
PostPosted: Fri Nov 20, 2020 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Received and installed the Olimex USB Isolator. Works like a charm.
Thanks !
Audio files: 211
PostPosted: Sat Nov 21, 2020 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
We were on a tight schedule and he would have had to have about 60 ground lifter plugs. But you know, Jamos, those old-timers all all idiots. Shocked
