  bingsatellites Mostly Ambient
 Forum index » How-tos
Dual rail PSU - Transformer compatibility
Page 1 of 1 [2 Posts]
Stavros
PostPosted: Mon Nov 19, 2012 6:08 am    Post subject: Dual rail PSU - Transformer compatibility Reply with quote  Mark this post and the followings unread
I will appreciate any help on my following two questions
I have a dual rail small power supply (+ 12, -12VDC) requiring a 2x15V Non Tapped Transformer (the PSU has two bridges requiring 4 AC cables in).
I have readily available a 2x15V Center Tapped Transformer (3 cables).
Could this Center Tapped one be used somehow, or I need to buy a new Non Center Tapped Transformer?
If a Transformer is quite large (3 or 4 times of a PSU requirement), could a second similar PSU also be connected to the same Transformer (parallel to the first one)?
Audio files: 254
PostPosted: Mon Nov 19, 2012 9:00 am    Post subject: Re: Dual rail PSU - Transformer compatibility Reply with quote  Mark this post and the followings unread
I would say yes,. you can use the center tapped transformer, just split the center tap into 2 wires so you'll end up with 4.
(I often do the opposite,. connect the windings to get a center tap).
As for using multiple PSU"s on one transformer,. I don't see why that would be a problem. I mean it's just like
hooking up multiple things your mains voltage (which is also the output of a transformer).
But maybe I'm completely wrong here, so better wait for some confirmation from someone else Wink
http://www.acidtrash.com/
