Joined: Apr 03, 2004 Posts: 19583 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat Nov 17, 2012 5:15 pm Post subject:
A bag full of of G2 demo compatible noodle patches |
I made the G2 demo compatible noodles that I did in the last two years or so available here.
A lot of these patches will have variations and will listen to CC2 and or notes played, CC119 too sometimes.
These were mostly made to be controlled from what happens in the electro-music chatroom. I made a chat bot for that (hellbo) which translates chat activity into signals for my synths (through MIDI for the G2 and through OSC for the pacarana). _________________ Jan |
Joined: Aug 08, 2009 Posts: 556 Location: Upstate New York USA
Audio files: 151
Posted: Sun Nov 18, 2012 7:01 am Post subject:
| Cool. Thanks for organizing them into the list of links. Now, where did I put my Nord demo program? |
JLS
G2 patch files: 274
Joined: Feb 04, 2005 Posts: 2129 Location: Nottingham, UK
Audio files: 150
Audio files: 211
G2 patch files: 92
[Q]
Posted: Tue Nov 20, 2012 7:28 am Post subject:
wow.. xmas has come early
Thanks Jan..  _________________ The internet allows your mind to travel. ~ [Q]. |
cebec
G2 patch files: 31
dorremifasol
Joined: Sep 28, 2006 Posts: 757 Location: Barcelona, Spain
Audio files: 6
G2 patch files: 47
Posted: Wed Nov 21, 2012 10:14 am Post subject:
Nice, thanks Jan!
So Bellbo plays the G2 depending on what happens in the chat room? amazing!  _________________ Cheers,
Albert |
Audio files: 116
G2 patch files: 317
Posted: Wed Nov 21, 2012 12:29 pm Post subject:
Hellbo ... played ... I've turned it off for now, but yeah that was what it did.
| dorremifasol wrote: | Nice, thanks Jan!
So Bellbo plays the G2 depending on what happens in the chat room? amazing! :D |
klangumsetzer
Audio files: 10
Posted: Thu Nov 22, 2012 2:16 pm Post subject:
yeah!
btw jan: no complaints from my colleagues the sounds from my office yet. _________________ best regards
eike
make a joyful noise! |
Audio files: 116
G2 patch files: 317
Posted: Thu Nov 22, 2012 2:41 pm Post subject:
| klangumsetzer wrote: | | no complaints from my colleagues the sounds from my office yet. |
cappy2112
Joined: Dec 24, 2004 Posts: 2088 Location: San Jose, California
Posted: Fri Nov 30, 2012 8:58 pm Post subject:
Re: A bag full of of G2 demo compatible noodle patches |
| Blue Hell wrote: | | I I made a chat bot for that (hellbo) which translates chat activity into signals for my synths (through MIDI for the G2 and through OSC for the pacarana). |
Sounds cool. I'd like to see that.
What is pacarana? _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
cappy2112
Posted: Fri Nov 30, 2012 8:59 pm Post subject:
| Blue Hell wrote: | I made the G2 demo compatible noodles that I did in the last two years or so available here.
Thanks for the demos.
Any chance you can put a zip file up there to get them all at once?
Audio files: 116
G2 patch files: 317
Posted: Sat Dec 01, 2012 4:40 am Post subject:
| cappy2112 wrote: | | Blue Hell wrote: | | I I made a chat bot for that (hellbo) which translates chat activity into signals for my synths (through MIDI for the G2 and through OSC for the pacarana). |
What is pacarana? |
http://www.symbolicsound.com/cgi-bin/bin/view/Products/Pacarana
But in reality it is a US army plan to dominate the future world by having a cheap network of computing distributed all over .. anyway .. while the systems are not needed you can make them beep.
As to to zip question ... Wget is your friend ... if anything I probably should upload the patches here instead.
As to the 'see' question .. it's just a bunch of red boxes, a black one, three laptops and and a floortop really ... a bit like ...
and some info about Hellbo.
Them big ears are everywhere
varice
Joined: Dec 29, 2004 Posts: 626 Location: Northeastern shore of Toledo Bend
G2 patch files: 46
Posted: Fri Jan 04, 2013 11:39 pm Post subject:
Hey Jan, thanks for sharing all of these patches As usual, much of your work is unique, with “outside of the box” type patching.
A case in point: while checking out these patches, after I loaded the 2011-11-14-01-08 patch and noticed a NoteQuant module named “red->blue”, I realized that this module is not being used at all as a note pitch quantizer. Instead, it is “down converting” a red (96kHZ audio rate) signal to a blue (24kHZ control rate) signal, with the purpose of running the following modules at the slower rate to reduce the patch DSP cycle load. If I had seen this great trick before, I did not remember it This is a trick that you have known for a long time already:
http://www.electro-music.com/forum/post-21760.html
A good trick to know indeed For example, I can use this trick as an option with my “mono monster” patches (which use up to nine pitch modulated oscillator modules) to significantly reduce the DSP load. _________________ varice |
Audio files: 116
G2 patch files: 317
Posted: Sat Jan 05, 2013 4:22 am Post subject:
| varice wrote: | | For example, I can use this trick as an option with my “mono monster” patches (which use up to nine pitch modulated oscillator modules) to significantly reduce the DSP load. |
Good you discovered it too
And thank you for looking at the patches! _________________ Jan |
