[New Project] vcNOIZ -- a harsh voltage controlled noise gen
Page 1 of 2 [37 Posts]
HexInverter
PostPosted: Fri Sep 21, 2012 8:45 am    Post subject: [New Project] vcNOIZ -- a harsh voltage controlled noise gen
Subject description: a DIY gnarly noise generator
Hey ladies and gents!
I've yet another module I am developing. It is a 1bit voltage controlled noise generator with sub-octave simultaneous outputs and voltage control of the pitch. It creates gnarly ass C64/chiptune sounding noise textures.
PCBs are for sale here!: http://www.hexinverter.net
Here is the feature-set:
Inputs:
- Expo. response CV input (-V to +V)
- Linear response CV input (-V to +V)
- Clock input (square wave, positive logic)
Controls:
- Pitch control (to tune base frequency, just like a VCO)
Outputs:
- Base frequency noise output (a little smoother sounding than the divisions) [audio coupled]
- Sub octave /4 output (gritty sounding) [audio coupled]
- Sub octave /8 output (gritty sounding) [audio coupled]
- Base frequency DC coupled gate output (for when wanting a random gate when using a slower clock/pitch rate)
- Internal clock output (there was an extra opamp, so I figured this could be useful)
Basic Audio Demo:
vcNOIZ -- a voltage controlled distortion module for analogue synthesis by hexinverter.net
vcNOIZ Voltage Controlled Noise Oscillator DEMO2 by hexinverter.net
Panels will be available at Re:Synthesis:
Watch the video for more info Smile
I'll have a PCB available if folks are interested!
hexinverter.net -- Shop DIY projects and modules for modular synthesis
sympleSEQ -- the simple to build analog step-sequencer
seqSQUARED -- the Analogue Pattern Generator
--> Put yourself on the hexinverter.net mailing list to be notified when in stock!
diablojoy
PostPosted: Sun Sep 23, 2012 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds good Hex
as usual i think i will want one.
You might need to slow down some , my cave is filling up fast . There's now over 200 boards in my backlog Embarassed damn never enough time Rolling Eyes
Wish i could take a sabatical for a year or two and just build.
Oh well i always said this would last me till retirement to finish if i was lucky.
ask where the hell am I
as good an answer as any
JingleJoe
PostPosted: Sun Sep 23, 2012 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Please Sir, may I have some circuit diagram?
As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
HexInverter
PostPosted: Sun Sep 23, 2012 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
No circuit diagram until it is done, sorry Smile There are some evil people out there that will snap this up and make it into a commercial module if they think it's worth it.
HexInverter
PostPosted: Sun Sep 23, 2012 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
diablojoy wrote:
sounds good Hex
200!? lol!!! That is a massive backlog xD
That would be a fun year or two!
HexInverter
PostPosted: Sun Sep 23, 2012 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Beta PCB layout complete Smile Dimensions are 60x93mm.
It might not be until next weekend that I can prototype it Sad Gotta go work on school stuff now...
HexInverter
PostPosted: Sun Sep 23, 2012 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Audio demo is up Smile
JingleJoe
PostPosted: Sun Sep 23, 2012 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I understand about the schematics, keep them secret, could you clarify one thing for me though: Is there a PIC or other programmable IC in it?
HexInverter
PostPosted: Sun Sep 23, 2012 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nopers! It is all discrete logic chips (CMOS) and analogue opamps! Smile
JingleJoe
PostPosted: Tue Sep 25, 2012 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh excellent Smile I like that, for reasons of longevity.
HexInverter
PostPosted: Tue Sep 25, 2012 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed sir! There are other benefits too -- there is no aliasing on the CV input Smile When you sweep the CV input knob, or feed a CV signal in, it is actually changing the clock (and thus, the pitch) in real time, in increments of one clock cycle (not aliased like with a microcontroller!)
Also, I am quite certain a microcontroller has different rise/fall times that effect the sound of the noise. I was comparing a similar noise routine I wrote on PIC to this CMOS circuit and they don't sound the same!
JingleJoe
PostPosted: Tue Sep 25, 2012 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Better sound; Jolly good but could you define aliasing? I may know it by another name ...
HexInverter
PostPosted: Tue Sep 25, 2012 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Aliasing is the "stepping" that occurs when reading (or generating) any analogue signal with a digital device (in this case, a microcontroller). Basically, the ADC (analogue -> digital converter) on a microcontroller is typically 1024 (10 bit) step resolution, so, as you turn the CV knob on a digital device, or input a control voltage, the device actually only has 1024 steps on the control.
This may sound like a lot, but it IS actually noticeable to the ear when you are talking about a VCO. You typically can hear faint stepping in the pitch coming out of digital VCOs that only use the built-in 10bit ADC. Of course, you can purchase and use a 12bit ADC to greatly increase the resolution you can read at, but, it's nowhere near as cheap. Already, you've probably surpassed the cost of the two (only) decently expensive parts on the non-microcontroller CMOS design...the two CD4006/NTE4006s Smile
JingleJoe
PostPosted: Thu Sep 27, 2012 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I see now Smile all of the science has been explained, thankyou. Your circuit is really quite good then if it is making digital noise without aliasing, carry on the good work old sport Wink
HexInverter
PostPosted: Thu Sep 27, 2012 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Haha, thanks for your kind words. I am happy to explain anything as far as I am capable of Smile
HexInverter
PostPosted: Thu Sep 27, 2012 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Euro panel rendering!
HexInverter
MU Panel Rendering:
HexInverter
PostPosted: Thu Oct 18, 2012 6:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, beta PCBs for vcNOIZ shall be ordered very soon, alongside the NeinOhNein Rimshot!
HexInverter
PostPosted: Fri Nov 23, 2012 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
vcNOIZ is now in preorder phase to help fund a production run!
The module is prototyped and is good to go! Woot!
You can preorder here: http://igg.me/p/282076?a=227451
HexInverter
PostPosted: Sat Nov 24, 2012 12:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
NOTE: The Bill of Materials and Mouser Cart has changed! I had to make some corrections to the BoM.
You will need to add another 100k resistor. The new BoM and Mouser Cart reflect this change.
HexInverter
PostPosted: Sun Nov 25, 2012 6:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the SMT circuit board rendering. Should be ready for the fab house now!
SPIKE the Percussionist
PostPosted: Sun Nov 25, 2012 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds NEAT!!!
more like the noiz of a 2600 than a C64 to me though!
[[more noiz!]]
- http://www.manipulate.net -
ASTROGENIC HALLUCINAUTING
CoRE - Troupe Music Director
DOGGEBI
morgue city
HexInverter
PostPosted: Sun Nov 25, 2012 6:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
SPIKE the Percussionist wrote:
sounds NEAT!!!
Haha! Well, whatever works for ya Very Happy
HexInverter
PostPosted: Tue Dec 04, 2012 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
New audio demos as well as beta module photos!!!
Taylor
PostPosted: Wed Dec 05, 2012 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool sounds and lovely PCB design. Very Happy Wish I could afford the Eurorack boards as it looks like fun. Any chance you'd offer the PCBs without the SMT already mounted, for those of us comfortable with SMT soldering?
musicpcb.com
Niio1
