bubzy
Joined: Oct 27, 2010 Posts: 450 Location: United Kingdom
Audio files: 47
Posted: Wed Nov 28, 2012 3:12 am Post subject:
Re: Enneatronic Spectralizer Subject description: Dronebox with 9 squarewave oscillators |
| Quote: | Nice work. Found a pic of someone viewing that display  |
hahahahahaha
phobos: damn you! too many nice builds, ive got build envy! ive also got a radio controlled helicopter spread over my desk so i cant build until i get my spare sparts aaaaaaaaaaaaaaaaa!
love that led display too! _________________ _Richard_  |
bubzy
Audio files: 47
Dragon's Lair
Joined: Dec 29, 2006 Posts: 184 Location: Nakusp BC, Canada
Posted: Fri Nov 30, 2012 11:57 am Post subject:
I finally got around to finishing my row of Frac modules, the modules are all of my own design, panels are from FPE.
1x Tuneable Noise, base on my pcb layout for the Liquid Hi Hat
1x Gate Delay (New version)
1x LPG, my own layout
3x Gate Delay (old version)
3x Voltage Controlled Clock, based on the Aries clock module
3x XR LFO, LFO based on the XR2206
2x 8 Channel Sequencers
The old version of the Gate Delay just delayed the start of the gate, it still ended when you released the key, I wasn't happy with that,
so I redesigned it, the new version has 4 modes,
Normal - works the same as the old version
Extended - Delays the start of the gate, and lets you extend the gate past the point where you release the key
Manual - delays the start of the gate, and lets you set a specific length, regardless of whether the key has been released
Timed - delays the start of the gate and keeps it on for the same length of time as the key was held down.
The sequencers can run of an internal clock, or the length can be set individually for each step, they also have a Cascade output so you can chain them together,
the time between triggering the next sequencer in the chain is adjustable.
I am currently working on a couple Midi projects (I'm using blue panels on them), and a cv keyboard retrofit for the cheap (M-Audio) Fatar keyboards
I am also in the process of building a CNC engraving machine, so I can start doing the panels myself.
265.47 KB |
| Viewed: |
64 Time(s) |
Posted: Fri Nov 30, 2012 1:32 pm Post subject:
| Quote: | | I am also in the process of building a CNC engraving machine, so I can start doing the panels myself. |
This has occurred to me as well. I took advantage of the Cyber Monday sales to get a PDF copy of "Build Your Own CNC Machine" on aPress, by Patrick Hood-Daniel and James Floyd Kelly. It uses a laminate router...
I'd be really interested to hear about anything you learn in the process. I don't think I'm ready to bite off on this project for a while, but I'm reallly interested for the longer term. |
Joined: Jan 15, 2011 Posts: 182 Location: Montreal, Canada
Posted: Thu Dec 06, 2012 6:20 pm Post subject:
Subject description: Tea Candle Noise Box |
This is a silly and simple little build for a laugh. After the disastrous Sweet32 Speaker Interrupter-Switcher Installation thing which will require some difficult debugging to get working, I decided to build something really quick & easy that was sure to work. Better that than give up electronics!
Inspired by PHOBoS' discovery that the flickering LEDs in dollar-store electronic tea candles make sound, I wired 3 of them up and sent the sound to a speaker, putting the whole lot in a wooden tea box. There's a volume knob and a switch to turn the speaker off, and tap wires for a line out.
A quick demo can be seen here: http://youtu.be/GE7RyhDhcyo
James.
| Tea candle noise box interior |
114.93 KB |
| Viewed: |
36 Time(s) |
| Tea candle noise box exterior |
116.81 KB |
| Viewed: |
34 Time(s) |
Audio files: 254
Posted: Fri Dec 07, 2012 7:32 am Post subject:
what a lovely box .
but to be faiir it's not my discovery, I think I got the idea from here.
But I had not seen them used in a lunetta before.
And is it just me or does it sound like they are communicating/arguing with eachother . I was actually
working on a circuit to make them 'listen' to eachother and respond, involving a shiftregister. Which is why I started
with them in my modular lunetta. (to save breadboard space) _________________ "My perf, it's full of holes!"
http://www.acidtrash.com/ |
Psyingo
Posted: Fri Dec 07, 2012 7:57 am Post subject:
| RingMad wrote: | This is a silly and simple little build for a laugh. After the disastrous Sweet32 Speaker Interrupter-Switcher Installation thing which will require some difficult debugging to get working, I decided to build something really quick & easy that was sure to work. Better that than give up electronics!
James. |
dollarama?! |
JingleJoe
Joined: Nov 10, 2011 Posts: 789 Location: Lancashire, England
Posted: Fri Dec 07, 2012 8:30 am Post subject:
That tea-box-fickering-candle thing is brilliant the sound makes me laugh, it just sounds so silly! but very effective  _________________ As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Green Dungeon Alchemist Laboratories |
Posted: Fri Dec 07, 2012 5:12 pm Post subject:
| PHOBoS wrote: | And is it just me or does it sound like they are communicating/arguing with eachother . |
Yeah, that's what it makes me think of too.
| Psyingo wrote: | | dollarama?! |
Yes. I bought several last year. Haven't checked if they still carry them this year.
| JingleJoe wrote: | | the sound makes me laugh, it just sounds so silly! |
Silly indeed!
Of course, I was thinking of having LFO's control the volume of each LED, but hey, this was supposed to be a quick, silly thing. I think the only thing I would do is maybe put a smaller speaker, anchor it better so it rattles the box less, and maybe put a few holes for the sound.
James. |
Joined: Jan 31, 2003 Posts: 17337 Location: Allentown, PA
Audio files: 107
Posted: Sun Dec 09, 2012 11:09 am Post subject:
Very cool. I like the arguing candles...  _________________ --Howard
my music and other stuff |
Posted: Mon Dec 10, 2012 8:05 am Post subject:
| mosc wrote: | Very cool. I like the arguing candles...  |
Actually, when one starts listening to them for a while, it gets pretty hypnotic and interesting.
And for those in Canada, the Dollarama indeed carries these electronic tea candles (at least until x-mas)... 2 for a buck, get 'm while they're hot. (Truth be told, I never checked if one can order just the raw LEDs from somewhere even cheaper).
James. |
Sonic
Posted: Mon Dec 10, 2012 8:21 am Post subject:
| Dollarama ftw! I picked up a cool LED-based strobe light thingy from there a while back. They're also handy for wooden enclosures for lunettas. And a million other things of course. |
emdot_ambient
Joined: Nov 22, 2009 Posts: 669 Location: Frederick, MD
sduck
Posted: Wed Dec 19, 2012 9:51 pm Post subject:
Last one of the year for me. And going out on a festive note!
I've had these pcbs for something like 4 years. Got started on the panel design 3 times, but finally finished it this time. It's a strange collection of knobs to try and make some kind of sense out of; maybe I got close.
Posted: Wed Dec 19, 2012 10:06 pm Post subject:
That's gorgeous and you fit it into 2 wide! My notes had me for sure doing it in 3....
I really like the use of color to keep it straight. |
sduck
Posted: Wed Dec 19, 2012 10:46 pm Post subject:
Yes - I've seen 3, 4 and 5U versions, but they all seem kind of large for what this module does. I mean, it's a great module soundwise, super flexible, but you're going to want 2 or 3 of them, and you can't take up a whole cabinet for these things, can you?
I will say this - those knobs are awfully close together - it takes some dedication and care to tweak the inner ones without moving the ones around it. |
Luka
ashleym
emdot_ambient
Posted: Thu Dec 20, 2012 8:47 am Post subject:
I'm not so sure I like the diagonal set up or the colored knobs, sduck, but I really like your approach. I've avoided buying that PCBs because of the panel real estate required. But you've shown it can be done in a reasonable amount of space. So kudos! _________________ Looking for a certain ratio since 1978 |
diablojoy
Joined: Sep 07, 2008 Posts: 729 Location: melbourne australia
Posted: Thu Dec 20, 2012 11:19 pm Post subject:
very nice layout sduck as always
I have 3 MPS's to do panels for soon, i think i will do something along similar lines . my panels are a little larger at 241mm high x 100mm wide though which should help a bit those knobs do look a little too close for my fat fingers  _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
Posted: Sun Dec 23, 2012 9:14 am Post subject:
The Sweet32 Speaker Interrupter-Switcher Installation Thing
After a few years of collecting speakers from stuff found in the trash, I finally got them off the floor and onto the wall. There are 47 speakers per panel, but only 16 per panel are wired up to the control box. The box takes a 2 channel input and randomly selects which of the speakers the sound is directed to (for each panel). The rate can be controlled by the knob, or via an external CV. There is also the optional interruption control on a per-channel basis... this cuts the sound going to a panel according to the rate set via the knob (or external CV). Alas, the box and the speakers are not very clean-sounding, so not just any audio is suitable. It is best to feed it with simple drone oscillators.
No video could really demonstrate what this installation sounds like in person, with the sound moving around. If you're in Montreal, Canada, maybe we could arrange a visit...
An automatic drone box for use with this thing is possibly in the works....
I've lost count of how many hours this thing took to make. I must be insane.
James.
| Overall view of the installation. |
235.22 KB |
| Viewed: |
41 Time(s) |
202.25 KB |
| Viewed: |
37 Time(s) |
| Inside the control box. Yeah, that's 32 MOSFET transistors in there! |
199 KB |
| Viewed: |
35 Time(s) |
Posted: Sun Dec 23, 2012 9:46 am Post subject:
Insane.... and amazing That looks excellent, and I wish I could hear it. |
Joined: Apr 03, 2004 Posts: 19593 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Dec 23, 2012 10:17 am Post subject:
| RingMad wrote: | | No video could really demonstrate what this installation sounds like in person, with the sound moving around. |
Can imagine, it looks great at least on the pictures and I like the idea too. _________________ Jan |
Audio files: 254
