  Antimon Antimon Waves
SOLVED: EAGLE users? I'm trying to generate parts lists...
Page 1 of 1 [4 Posts]
Dougster
PostPosted: Tue Nov 27, 2012 5:27 pm    Post subject: SOLVED: EAGLE users? I'm trying to generate parts lists... Reply with quote  Mark this post and the followings unread
Well, the only tools I have found so far output a complete parts list from an entire schematic/board project. (BOM-EX rules BTW!) Cool
However, I have 18 pages of schematics for the project I'm trying to finish up and I'd like to output a separate parts list for each page. That way I have a list of all power supply parts and a separate list of all parts in the BD section, the SD section, etc. So far, I've had to either 1) output a complete list of all parts and edit it to suit, or 2) delete all but the current page of the schematics and output a parts list for it. Neither of these is a particularly optimal solution.
Does anybody know of a User Language Program (ULP) or some way of using attributes or something to make it easier to output a list of all the parts for each section of my design?
Doug
Once you start down the modular path, forever will it dominate your destiny!
Blue LEDs are evil.
Dougster
PostPosted: Wed Nov 28, 2012 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I solved it. I posted my script on the EAGLE forum, but figured I'd put it here too, since this is my favorite forum. Cool
EAGLE really has a weird/interesting/nice scripting system. This is a ULP file, which is written in a C-like language. ULPs can go through a library, a schematic, or a board and process almost anything. Interestingly though, you can't actually change anything with a ULP, so you generate a command script that is run when you use the exit() command...
Code:
#usage "<b>Adds PAGE number attribute to each part on each page of a schematic.</b>";
string Version = "0.10";
string tmp = "";
string Message = "";
string Script = "";
if (!schematic) {
  dlgMessageBox("Start this ULP from a Schematic...", "OK");
} else {
  schematic(SCH) {
    sprintf(tmp, "Schematic Name:\n%s\n", SCH.name);
    dlgMessageBox(tmp);
    SCH.sheets(S) {
      sprintf(Message, "Sheet %d\n---------\nParts:\n", S.number);
      S.parts(P) {
        sprintf(tmp, "%s\n", P.name);
        Message += tmp;
        sprintf(tmp, "ATTRIBUTE %s PAGE '%d';\n", P.name, S.number);
        Script += tmp;
      dlgMessageBox(Message);  // Dialog box with list of parts on page
  //dlgMessageBox(Script);  // Debugging - show script before executing
  exit(Script);
Regards,
Doug
Blue LEDs are evil.
mahjo
PostPosted: Tue Jan 29, 2013 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Doug,
thanks for that script. Do you create ULPs on a regular basis?
mahjo
PostPosted: Tue Jan 29, 2013 3:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Update: I found some useful ULPs here. I didn't know it was that easy to find help.
