4011 drums pcb...
Page 2 of 4 [81 Posts]
Psyingo
PostPosted: Sun May 13, 2012 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Paradigm X wrote:
What are the power requirements? 15v too much? Cheers
I use 12v but any voltage over the cmos range should be fine. sound will change depending on supply voltage, but it should work fine. I can test more thoroughly when i get the prototype.
Paradigm X
PostPosted: Mon May 14, 2012 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
Sorry, not trying to tell you what to do but if you post at muffs youll also likely get a ton more enquiries, poss making it cheaper Smile
Cheers, ben
loydb
PostPosted: Mon May 14, 2012 7:59 am    Post subject: Reply with quote  Mark this post and the followings unread
In for two please!
Psyingo
PostPosted: Thu May 31, 2012 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE:
prototype pcb has been shipped. batch pcb says it will arrive in 5-28 days, hopefully its on the shorter side of things.
magneticstripper
PostPosted: Thu May 31, 2012 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
can i put in for 2?
Psyingo
PostPosted: Mon Jun 11, 2012 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Prototype pcb has arrived. I will populate soon to check for bugs n such.
Psyingo
PostPosted: Mon Jun 11, 2012 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mikmo
PostPosted: Tue Jun 12, 2012 3:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice compact board
Stay Cool
Mikael
http://www.mikmo.dk
baudrate
PostPosted: Thu Jun 14, 2012 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am defiantly interested in one of these!
Mongo1
PostPosted: Fri Jun 15, 2012 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Can someone point me to some more info on this? Sound samples etc?
I'm definitely interested but would like to know a little more....
Thanks
Gary
Psyingo
PostPosted: Fri Jun 15, 2012 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/topic-52786.html
Here is a link to the modular drum machine that uses the same 4 drum voices. Read about the twin t drums in that post. There are some sound samples down the page.
I will write and post a construction manual once i get the board verified.
The drums are a classic twin t ringingfilter configuration, similar to old organ drum machines or even some the tr606 and tr808 sounds. The sounds can easily be triggered from a piezo or audio impulses, and of course triggers from modular synths, etc. but when triggering from a small signal source the Synth drum bend will not work.
The capacitor values are not fixed, but i will supply some values for various drum ranges.
Mongo1
PostPosted: Fri Jun 15, 2012 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - I'm definitely interested!
Gary
Jampy
PostPosted: Thu Aug 16, 2012 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are there any of these PCBs still available?
schmelfhelp
PostPosted: Sun Aug 19, 2012 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm also wondering if there are any pcbs still available. Smile
Draal
PostPosted: Sun Aug 19, 2012 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
My belief is that he just received the initial pcb's and was going to run some tests on em'. When a project is really ready, people tend to create an obvious new thread for taking orders/info, etc.
Zontar Prevails!
Psyingo
PostPosted: Sun Aug 19, 2012 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, draal is right. I received the prototype pcb but there was an error so I've had to re order it. Ill let you know when it's easy.
-minus-
PostPosted: Tue Aug 21, 2012 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, can you repost the sounds? I click on them in the original thread and get 404 Error. Thanks. Maybe post them here?
textual
PostPosted: Tue Aug 21, 2012 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes the pics with schematics from original modular drum machine thread are also down..
______________________
www.dlbelectronics.com
www.textualmusic.com
www.mercuryprogram.com
Psyingo
PostPosted: Mon Oct 22, 2012 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I am happy to announce that I have reordered the prototype PCBs.
Once i have the prototype tested i can start shipping these little guys out.
should be 2-4 weeks to arrive.
the price will be EDIT: 10$ a board +shipping.
Psyingo
PostPosted: Mon Oct 22, 2012 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
and here are the sound samples, reposted.
The metallic percussion sounds are NOT on this board.
http://www.voxinfinitus.net/~psyingo/mp3/cmosdrumdemo2.mp3
http://www.voxinfinitus.net/~psyingo/mp3/cmosdrumdemo.mp3
Psyingo
PostPosted: Wed Nov 21, 2012 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
stiill waiting on the prototype pcbs...
would anyone be interested in buying a kit of components if i were to make one available?
Psyingo
PostPosted: Fri Nov 30, 2012 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
here are some pictures of the pcbs. The first shows the top and bottom of the pcb, the second is populated with one voice tested.
PostPosted: Fri Nov 30, 2012 10:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interested in the PCB at a $10 or so price point, not a kit so much.
What are all the unused connections in the second photo?
Edit:DUR I see the $15 price now, that's just fine, still interested Smile
Psyingo
PostPosted: Fri Nov 30, 2012 10:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
The board is split up into quarters, the part that has the wires coming off is one quarter, or one drum. the other drums don't have any controls yet, so those unused connections are for pots and in/outs
Draal
PostPosted: Sat Dec 01, 2012 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd buy a kit on a heartbeat. But if not available, a pcb alone is ok.
Zontar Prevails!
