4017 vs. 4022 for simple sequencers?
Page 1 of 1 [7 Posts]
sonicwarrior
PostPosted: Thu Dec 06, 2012 11:43 am    Post subject: 4017 vs. 4022 for simple sequencers? Reply with quote  Mark this post and the followings unread
I recently found out that there is the 4022 chip with 8 outputs which looks otherwise exactly like the popular 4017 with 10 outputs.
Musically 8 outputs make more sense and many sequencers based on it are using only 8.
So why does nobody use a 4022 instead of the 4017? Confused
slacker
PostPosted: Thu Dec 06, 2012 11:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I've never used one because until about 30 seconds ago I'd never heard of them Smile
Dave Kendall
PostPosted: Thu Dec 06, 2012 1:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Only thing I can think of, is that 4022s are rarer, and have a different pinout. The CLK, ENABLE, CARRY OUT and RESET pins are the same as the 4017, but the pinout for the Q outputs is different.
Apart from the pinouts, the Motorola datasheets for the 2 ICs seem identical.
"The Higgs Bosun's finally been found. So where's the Higgs Captain?"
analog_backlash
PostPosted: Thu Dec 06, 2012 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a good point that you've made sonicwarrior. Nearly all simple sequencers I've seen are based on the 4017 (including ones that I've thought of myself). Musically, the 8-step 4022 seems more sensible. I'm sure that effectively they are the same (apart from step length and pinout as already mentioned), as most manufacturers seem to put them on the same data sheet (I have the NatSemi and SGS-Thompson ones to hand). The only problem I can see is that an 8-step 4017 can be expanded to a 16-step 2 x 4017, but this uses some of the unused outputs. With the 4022, there are no unused outputs, so this is more difficult (or impossible?) to achieve.
I am planning to build (eventually) a clock divider/distributor/gate sequencer which I was designing using 4017s, but I've just looked at my stash of chips and I have six 4022s. I think I might use them, since I don't have any other urgent use for them.
Gary
JingleJoe
PostPosted: Fri Dec 07, 2012 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
that sounds like a challenge Smile I think it is possible but we'll have to experiment first Wink
update: without extra logic it may be impossible however you can make a 14 step as it is Smile
As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
analog_backlash
PostPosted: Fri Dec 07, 2012 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I knew that someone would rise to that, hence the (?)! Very Happy Just thinking about how the 14-step could be done without extra gates - I'll work it out eventually...
Gary
JingleJoe
PostPosted: Fri Dec 07, 2012 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Gary
ah, slight misunderstanding, the 16 step sequencer with 4022s requires extra gates/logic but the 14 step is possible with only two 4022s.
Niio1
