Simple LFO schematic, opinions?
Page 3 of 3 [52 Posts]
Goto page: Previous 1, 2, 3
JingleJoe
PostPosted: Fri Dec 07, 2012 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know about RF (radio frequency) noise but there's allways the problem of induction- any two wires or pcb track running near one another can induce a current in one another so if you have any high currents flowing through wires, the larger current will create a greater electromagnetic field around the wire thus inducing a signal in nearby wires.
Reduce the current flowing to solve this.
Also that 100 ohm resistor sounds like a bad idea to me, I've never seen that done before, maybe a 10 ohm resistor to prevent direct shorts but 100 ohm in line with the chip? That'll just power starve the IC.
Try putting a nice big cap, something like 470u or 1000u accross the power supply Smile I have done that in the past to remove interference caused by 555 timers and other oscillators in high gain amplifiers (gain>1000) which were all on the same power supply.
As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Rolbista
PostPosted: Fri Dec 07, 2012 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, i'll try that, one more thing, I'm currently using a switching transistor with an LED for a rate indicator, but could i just put an LED in parallel with whatever i'm modulating with the LFO? stick it on the output?
*EDIT* would it be a good idea to ground all the unused pins?
Niio1
