  bingsatellites Mostly Ambient
A new Lunetta module ...... MP3 RELOADED
Page 1 of 1 [8 Posts]
Rykhaard
PostPosted: Sat Mar 07, 2009 8:50 pm    Post subject: A new Lunetta module ...... MP3 RELOADED
Subject description: with photo and mp3
Otay. A slightly different version of this module had been done by Tom Bugs, some time early last year. I have also done a slightly different version with my KAOS LFO. So it may not be completely new, but may I present to you:
The 4 Stage Oscillator! Smile
I've attached to this message:
- a photo of my Deathlehem Machine as he currently stands, with the test board for the 4 Stage Oscillator, lying on the floor of the machine.
- a 3+ minute mp3 example file of the module
- a VERY quickly done schematic for the circuit
This module allow you to have 4 pots, that control the pitch, of a single CD40106 oscillator, using the CD4052 dual 1:4 / 4:1 multiplexer
Control inputs A and B decide which of the 4 sections are currently conducting electricity: 0, 1, 2 or 3 of both halves of the 4052. (No, each of the 2 sections do not operate independently.)
The user has the choice of selecting which of the 4 sections is action at at time they choose by sending a HIGH to either or both of the Control Inputs.
When no HIGH is sent, both of the inputs are Grounded through 100k resistors. There are also protection diodes on the inputs to the Controls, to make sure that no negative voltages make it through.
The mp3 file that I have included in this message starts out fading in with a shrilling constant shriek. This is due to my using 2 x CD40106 oscillators to individually control the ON / OFF nature of each of the Control Inputs. At the very beginning of the track, I have both of the oscillators operating at their highest frequencies. (Approximately 4700hz and 250hz.)
A gradually drop the speeds of each of the controlling oscillators, towards the point where you're able to hear the 1st one now causing the CD4052 to switch between 2 inputs and finally, where you're able to make out 4 individual pitches. That is where you're able to hear each of the 4 'pitch' controls for the oscillator who's timing is determined by which of the 4 pots at the CD4052 are currently active.
For a few moments I change the pitch of each of the 4 pitch controls to demonstrate that, as well as changing the frequencies of the 2 control oscillators.
Finally, I start to slowly increase the speeds of the control oscillators to bring the audio back to the initial shrieking that the track started out with.
I hope others out there who are building Lunetta machines, enjoy this idea! Smile I came up with it late this afternoon and built the test circuit in about 2 1/2 hours, successfully using 2 of the 14 or 16 pin chip PCBs that I made, yesterday. (I will NOW be making a whole bunch more of them, as they help to make building, a breeze. Smile )
In a couple of days I hope to get this entire new panel completed. It will consist of:
- 4 more CD40106 clocks. 2 of them with the lowest speed of 0.5hz
- the new 4 Stage Oscillator
- 2 more 4 Bit Shift Registers
slacker
PostPosted: Sun Mar 08, 2009 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
That's really cool, thanks for sharing. I'll add it to my list of stuff to play with.
I can't listen to the mp3 though, just says file not found Sad
Rykhaard
PostPosted: Sun Mar 08, 2009 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Not a trouble in sharing! Smile
Thankee greatly for letting me know of the download failure Slacker! I just confirmed that and RE-uploaded the MP3, confirming it's existence this time. Smile
slacker
PostPosted: Sun Mar 08, 2009 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds great.
droffset
PostPosted: Mon Mar 09, 2009 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I like it, will build one too!
acidblue
PostPosted: Tue Dec 11, 2012 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I know this is an old post but could you re-post the Shem???
Since the mp3 and the schem don't show up any more.
I got here thru the Link-O-Rama sticky post.
analog_backlash
PostPosted: Tue Dec 11, 2012 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know the ins and outs of it, but Rykhaard had a major falling out with this site and no longer deals with it. You can still see his stuff on:
http://deathlehem.com/php/forums.html
The only problem is, you have to register and it usually takes quite a while before you hear back.
Gary
acidblue
PostPosted: Tue Dec 11, 2012 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
E Gads!
Thanks for the reply. Very Happy
