DS 7 clone
Page 15 of 19 [453 Posts]
Goto page: Previous 1, 2, 3, ..., 13, 14, 15, 16, 17, 18, 19 Next
xpmtl
PostPosted: Wed Aug 15, 2012 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
ici :
http://www.befr.ebay.be/itm/LM13700-2-Amplis-Op-OTA-LM13700-/180733648181?pt=FR_YO_MaisonJardin_Bricolage_ElectroniqueComposants&hash=item2a14909d35
http://sdiy.xpmtl.net
o-live
PostPosted: Wed Aug 15, 2012 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you
but is not my question ,i search the bill of material (part list)
of ds7 /ds8 who used teh lm13700
and if is possible the component layout of the circuit diagram you can see on firts page of this topics .
feggster
PostPosted: Sun Aug 19, 2012 5:36 am    Post subject: Reply with quote  Mark this post and the followings unread
@ o-live, for parts list and layout: http://m.bareille.free.fr/ds7clone/ds7.htm and page 2 of the thread shows the jumpers required for the lm13700.
o-live
PostPosted: Sun Aug 19, 2012 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you so much for reply Smile
anyone know the real difference with the ds8 and how upgrade ds7 to ds8 ?
and do you have found how to use the free pins of teh lm13700 ?
jumunius
PostPosted: Sun Aug 19, 2012 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Only difference is the DS8 adds a noise source I think.
-Jim
umschmitt
PostPosted: Mon Aug 20, 2012 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
You don't need to use them here, 4 of them are for built-in buffers, the remaining 2 for so-called linearizing diodes inputs (see datasheet).
::U::N::S::C::H::N::E::L::L::
o-live
PostPosted: Thu Aug 23, 2012 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok ihave see the datasheet but don't understand what is diode buffer Embarassed
now i have press'n'peel a board ,when ihave time i continue
(i try to add a 2044 filter inside and a germanium distortion)
thank you for your help
nikitsan
PostPosted: Thu Dec 13, 2012 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I got coron ds7 clone soldered, cased and working! But...
I have 1M pot on LFO speed, and my LFO is runing too fast, i can`t regulate it from slow freq (5-10Hz).
Now it`s sounding like this http://m.bareille.free.fr/ds7clone/ds7strange.mp3 in minimum.
How can I get slower LFO ? like this one http://m.bareille.free.fr/ds7clone/MartiansChronicle.mp3 ???
feggster
PostPosted: Thu Dec 13, 2012 4:09 am    Post subject: Reply with quote  Mark this post and the followings unread
dnny posted on page 1 :
'for "deeper" bass on VCO replace R11 (560ohm) whit 100ohm'
maybe that will help.
nikitsan
PostPosted: Thu Dec 13, 2012 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
i don`t need deeper bass, i want slower LFO Rate...
feggster
PostPosted: Thu Dec 13, 2012 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
right you are Very Happy
I think I used a 2m2 pot on mine, you could try that.
richardc64
Audio files: 26
PostPosted: Thu Dec 13, 2012 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or use a larger cap for C3.
"I’m a New Yorker, and I know a con when I see one.” -- Michael Bloomberg
nikitsan
PostPosted: Fri Dec 14, 2012 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
thnx i will try it...
nikitsan
PostPosted: Wed Jan 02, 2013 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
You was right about a cap!!! my cap was 472 instead 473.
thanks alot Very Happy
ElektroBear
PostPosted: Thu Feb 07, 2013 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi first post after lurking for quite a while:)
Is there anyone still active on this forum who has dnny's high resolution dual DS7 pcb layout? Iam looking to build one and the lo resultion one just doesn't cut it for me.
ElektroBear
PostPosted: Sun Feb 10, 2013 4:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I got a hold of dnny so if anyone wants the dual board layout just drop me a line.
ElektroBear
PostPosted: Thu Feb 14, 2013 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will get this thread up and running again. Otherwise iam gonna hve to start my own.
I did this with dnnys dual board. i simply hacked of half of it.
Should i ground the "orphaned" pins?
 Filesize:  20.28 KB
 Viewed:  535 Time(s)
feggster
PostPosted: Fri Feb 15, 2013 4:22 am    Post subject: Reply with quote  Mark this post and the followings unread
ds7 'fixed' scratch it wasn't broke! i etched/built one of dnny's dual boards it worked great.
i guess it is a good idea to do a single one, although seems a shame to waste half a lm13700.
p.s. I built the ak47 ds8 that works great too.
edit: pin 6 of lm13700 is v-
sonicwarrior
PostPosted: Fri Feb 15, 2013 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why not make it dual then?
ElektroBear
PostPosted: Fri Feb 15, 2013 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Iam making this on the request of a friend who runs All Out Dub/step Soundsystem and he wants a single to start with.
Iam thinking about making a DIL-6 (or is it 8 pins on the CA3080) for the surfacemount version of the 13700 so you can just plop it on the original board layout.
ElektroBear
PostPosted: Fri Feb 15, 2013 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh and remember the image i posted is copperside up so topright pin on the 13700 is number one and as far as i can see i need to run a path or a jumper from pin 11 to V+. but that should be it.
PostPosted: Sat Feb 16, 2013 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
But if you have a dual and want a single, you just use one, right? Smile
ElektroBear
PostPosted: Sat Feb 16, 2013 5:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah but i dont want to make a dual board since for it to work you need to populate both boards.
and by fixed the meaning is that i enlarged all pads
ElektroBear
PostPosted: Thu Feb 21, 2013 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pin 11 had to be routed aswell on the single board. so iam finishing it tomorrow hoping to have it usable on saturday since my friends are performing then.
I routed pin 11 to what i think is V- minus on the board. so this should work have a look. next step is building the dual board for myself.
ElektroBear
PostPosted: Thu Feb 28, 2013 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Alas i have not gotten my version of this to work.
So iam gonna start building the dual one tomorrow i just need to stock up on resistors.
