Nord Lead 1 Modification
Page 1 of 1 [17 Posts]
cbright9
PostPosted: Sat Nov 03, 2012 10:08 pm    Post subject: Nord Lead 1 Modification Reply with quote  Mark this post and the followings unread
Hello,
Recently i cut my nord lead 1 in half. it took up too much space so i opened it up, found a whole other PCB that was responsible for a large part of the keys and so i removed it and found that it still works. so my next step was cut the rest of the nord chassis away. So it is now 1 and a half octaves. the issue im having is this:
When i turn it on it says 2.3 i believe, and then says rA and then operates fine except for the pitch bend and the mod wheel do not work at all. what is going on here?
 Filesize:  953.56 KB
 Viewed:  124 Time(s)
Muied Lumens
Audio files: 204
PostPosted: Sat Nov 03, 2012 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Muied Lumens Base Star
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Nov 04, 2012 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Uh...
You are asking what's going on here...?
Very Happy Very Happy Very Happy Very Happy
(Synth has been reduced to fit the page...)
Anyway, the main operating part of the OS doesn't find the Keyboard any more, so it assumes it is a Rack. Probably you cut away something important...
Maybe someone from Clavia can tell you what to do. Sending some parts to install.
Wout
cbright9
PostPosted: Sun Nov 04, 2012 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
i didnt cut anything other than the metal that cases the synth and the extra plastic that the keys i removed were connected to. there are 2 PCBs that are responsible for the keys; one large PCB with the higher pitched set of keys that starts after the last key you see in the pic, and one PCB that starts with the lowest pitched key that continues to the last key you see. i simply unplugged the large PCB and cut the case down to size. it really is a cool modification. (i admit my metal working skills could use some work)
At any rate, im assuming that "rA" means its in rack mode? is there any way of toggling between the 2 modes?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Nov 04, 2012 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, the synth is doing it all by itself. When it detects the Wheel, PitchStick and Keyboard it 'knows' it is a Lead, otherwise it will be a Rack. Or the connection between Wheel and Stick is gone or it has to find the Keyboard.
I don't know exactly, but Clavia can tell...
Wout
Audio files: 254
PostPosted: Tue Nov 06, 2012 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
nice mod! Laughing Shocked
http://www.acidtrash.com/
bubzy
Audio files: 47
PostPosted: Tue Nov 06, 2012 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, cutting your synth in half.... thats a friggin GREAT idea.
please let me know the tools you used to do this, looks like a real neat job (im guessing you used a blowtorch and a spoon).
thanks
_Richard_ Smile
cbright9
PostPosted: Tue Nov 06, 2012 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Ill admit, its not the cleanest job, but then again, neither was your (mom and/or sister), and while im making valid points, with the few issues the board is having, it still functions better than your (mom and/or sister).
The only thing your underaged reply to my post is missing is the wonka meme. So i did it for you...
Grow up
 Filesize:  81.17 KB
 Viewed:  2314 Time(s)
bubzy
Audio files: 47
PostPosted: Tue Nov 06, 2012 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
i would be offended by your post but
a) im too dumb to understand it
b) the image you posted makes me laugh so much, i mean, whats the chances of someone else actually saying EXACTLY the same thing i did? genius
_Richard_ Smile
cbright9
PostPosted: Tue Nov 06, 2012 11:28 am    Post subject: Reply with quote  Mark this post and the followings unread
"crickets"
bubzy
Audio files: 47
PostPosted: Tue Nov 06, 2012 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
 Filesize:  53.35 KB
 Viewed:  2289 Time(s)
_Richard_ Smile
audiodef
Audio files: 27
PostPosted: Tue Nov 06, 2012 12:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now that's a sticky wicket!
Audiodef
Synthetronica
Gentoo Studio
bubzy
Audio files: 47
PostPosted: Tue Nov 06, 2012 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
i think its a wicky sticket
_Richard_ Smile
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Nov 06, 2012 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please, keep the discussion nice and friendly.
Wout
[forum moderator]
audiodef
Audio files: 27
PostPosted: Tue Nov 06, 2012 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe it's wicked sticky.
Audiodef
Synthetronica
Gentoo Studio
pablomastodon
PostPosted: Wed Nov 07, 2012 6:41 pm    Post subject: NL1 Mod
Subject description: keeping it friendly
1) check wire connections from mod wheel and pitch stick to panel board
2) check C17 and C19 on panelboard. The config is NOT auto-driven. The keyed versions use 0.1uF caps in those positions; for the rack versions those are replaced with jumpers.
just my two cents, but someone who does a total hack job, literally, on this synth, after which the pitch stick and mod wheel no longer work, then joins forum as noob seeking free advice on how to undo the damage...well, that someone should be coming with a large degree of humility and some thick skin, because a certain level of mild teasing/abuse can be expected (and is probably deserved)
audiodef
Audio files: 27
PostPosted: Fri Dec 14, 2012 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
The craze is catching on, it seems.
http://sphotos-h.ak.fbcdn.net/hphotos-ak-ash3/546873_10151290011387348_1293076051_n.jpg
http://sphotos-b.xx.fbcdn.net/hphotos-ash4/251570_10150268974157348_6004973_n.jpg
Audiodef
Synthetronica
Gentoo Studio
Niio2
