measuring resistors with multimeter
Page 1 of 1 [5 Posts]
olledahlberg
PostPosted: Sat Dec 15, 2012 4:58 am    Post subject: measuring resistors with multimeter Reply with quote  Mark this post and the followings unread
Im testing some resistors with my multimeter (470 K .25W 5%), and I get some strange readings. The resistors are totally new, but when I start measure, the multimeter reads ~1M ohm at first, and then the resistance drops to 470 K in some seconds. Are these resistors crap or ok to use for synth builds?
/Olle
Audio files: 116
G2 patch files: 317
PostPosted: Sat Dec 15, 2012 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe it's time to change the meter's battery?
KnobHell
PostPosted: Sat Dec 15, 2012 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you test leads in good order? Are you getting a solid connection? Every surface clean that needs to make contact?
I have clip leads on my voltmeters, at least most of them. Several times a year I'll have to fix an resolder connectors back on. They do wear out if you use them a lot.
analog_backlash
Audio files: 19
PostPosted: Sat Dec 15, 2012 9:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Ditto the comments above. I've found that one of my meters tends to go a little weird before the "official" battery low indicator comes on. Also, I made up replacement croc clip leads from scratch as I'd been having lots of problems with them. It's an autoranging meter and if there is a poor connection anywhere, it cannot settle on a true value. With the hand made leads, I'm now getting consistent results again (which also more-or less agree with my older meters).
Gary
olledahlberg
PostPosted: Sat Dec 15, 2012 1:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank guys for the thoughts, Ill check if the connections and battery has gone bad
AmbiphonicDSP
