am4d
Posted: Thu Nov 08, 2012 11:15 am Post subject:
DR-110 |
Hey guys
I'm going to mod this 110 I've picked up and was hoping for a little advice.
Would anyone recommend using any particular apms for the individual outs or are they loud enough as it is?
Regarding the trigger inputs; Is it plausible to do this using an arduino? Only because I have one laying about. (Never used PIC before either)
I don't think you can get negative voltage from an arduino, but maybe the arduino and 4049 can achieve this? I'm thinking the arduino might not need the 4050? (What does the 4050 do?)
Failing that i'll take the PIC route, but i'm not sure where to begin with that...
I was thinking out mounting it all with *tonal* mods in a little hammond case for triggering with modular ect.
Sorry for all the vague questions
Any advice you guys can give would be swell  |
creekree
Joined: Mar 30, 2006 Posts: 183 Location: Morgenland Neukölln
Posted: Sat Nov 10, 2012 2:44 pm Post subject:
what do you want to use the arduino for?
adding trigger inputs to the dr110 is trivial - look at the schematics and identify the trigger input lines on the ribbon cable that connects the two boards.
to use a trigger signal with those inputs, you will need to convert it from v-trig to s-trig (which means, a simple short to ground).
use the "moog trigger converter circuit" to do that.
http://www.cyborgs.de/synthesizer/faq/V-S-Trigger.JPG |
THeff
Audio files: 25
Posted: Sat Dec 15, 2012 7:46 pm Post subject:
Perfboard Dr-110 Voices |
This is my second post today. The first was about the Hammond B3 Propeller, and this one is about another project I have been working on the last few weeks. I have never owned a DR-110 or played with one, so I decided to try and perfboard all of the DR-110 voices and see what they sounded like. Here is a little demo of the perfboard. I mentioned the Propeller B3 post because I am using the same MIDI file here but this time all of the instruments in the MP3 demo are from a Yamaha MU-50 except the drums. All of the drums are from the DIY DR-110 board. I used BC550 and BC560 transistors throughout except for the snare drum, that was a 2SC945 with a very high HFE.
The row of eight transistors in the top middle of the board are inverters and signal conditioners for the triggers. The blue DIP resistor array are the eight input triggers. I am going to add a small 8 pin PIC microcontroller to provide the the four sequential triggers needed for the clap voice.
Regards,
Theff
132.32 KB |
| Viewed: |
48 Time(s) |
 Download |
| Filename: |
Green Eyed Lady - DIY DR-110 Drums.mp3 |
5.29 MB |
| Downloaded: |
75 Time(s) |
Dan Lavin
Joined: Nov 09, 2006 Posts: 602 Location: Spring Lake, Mi, USA
Audio files: 20
Posted: Tue Dec 18, 2012 11:54 am Post subject:
Theff:
That is some crazy amount of perfboarding! I thought of doing this in the past but knowing the number of connections made me sober up! I ended up buying a less-than-perfect DR110 for a reasonable price and completing it that way. Feel free to use my PicAxe program to do the hand clap triggers. Nice job! _________________ Synth DIY since 1977! |
THeff
Audio files: 25
Posted: Tue Dec 18, 2012 6:00 pm Post subject:
Hey Dan,
Thanks, I started out just wanting to see what the cymbals sounded like and then couldn't stop building. I built each voice one at a time and tested them as I went along. Thanks for the PicAxe suggestion!
Regards,
Theff |
richardc64
Audio files: 25
Posted: Wed Dec 19, 2012 7:49 am Post subject:
| Dan Lavin wrote: | Theff:
That is some crazy amount of perfboarding! |
It's hardcore Sounds authentic, too! _________________ "It's quite OK to make music with tea spoons and rubber bands!" -- Blue Hell |
THeff
Audio files: 25
Posted: Wed Dec 19, 2012 5:52 pm Post subject:
Thanks richardc64!
I was surprised how good the OH, CH, and Cymbals sounded compared to most of the white noise/multi-oscillator circuits that I played with before. That's what kept me building the additional voices. Boss really did their homework when they designed the filters and VCA envelopes for the DR-110. Simple but very effective.
Theff |
Joined: Aug 08, 2009 Posts: 544 Location: Upstate New York USA
Audio files: 151
Posted: Tue Jan 08, 2013 6:25 pm Post subject:
I love this song. It is a classic from the early '70s and it shows off your drums quite nicely.
Steve |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Wed Jan 09, 2013 3:48 am Post subject:
A beautiful,
Awe inspiring,
and, given my current, chaotic, construction circumstances,....
slightly frustrating build. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
Paradigm X
Joined: Feb 15, 2011 Posts: 251 Location: Null and void
Posted: Wed Jan 09, 2013 5:21 am Post subject:
Yeah brilliant job THeff, awesome.
I saw your perfboarded klee too, crazy. |
creekree
Posted: Wed Jan 09, 2013 12:55 pm Post subject:
Holy sh.. THeff!
That is some lovely breadboarding!
Would you mind sharing the PIC code? I totally forgot about those four essential clap triggers. I modded mine years ago - and it has been on constant loan to a friend in Belgium BUT I he is coming over next month, and he will bring it back!
I think I will work on it some more then. |
THeff
Audio files: 25
Posted: Thu Jan 10, 2013 5:02 pm Post subject:
Thanks Guys!
I have only done a very quick and dirty version of the PIC code using a 12F675. I am going to clean it up soon and will certainly post it here when it's done.
Regards,
Theff |
