  bingsatellites Mostly Ambient
S&H negative V out
Page 1 of 1 [7 Posts]
robboten
PostPosted: Sun Dec 16, 2012 6:14 am    Post subject: S&H negative V out Reply with quote  Mark this post and the followings unread
Having a strange problem with my S&H part of the noise/S&H pcb. The noise part works great, the random gate and the gate from S&H works (the led blinks and I get about 10V gate, which seems a bit high). But the S&H out clicks a bit and gives -10VDC out. I have changed the trans, the caps and the ICs, but no change. Anyone have clue how I could proceed?
iopop3
PostPosted: Mon Dec 17, 2012 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Make sure you're not feeding it a too hot signal. I think mine behaved the same, had to limit the peak to peak voltage on the noise in order to make it work properly.
I think the S&H only handles 6-8Vpp? I could be wrong, search this sub forum and you should find the posts discussing it.
EDIT: See this thread, http://electro-music.com/forum/topic-47352.html
robboten
PostPosted: Mon Dec 17, 2012 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Thx for your reply. Unfortunatly I have tried lowering the resistor value and by then the voltage peaks for the noise. It makes no difference... It also makes no difference if I use another noise module or VCO as input or any other signal/gate/LFO as the other input.
robboten
PostPosted: Fri Dec 21, 2012 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
how is the values around c4 to supposed to be like? I have around 0-10.45VDC in and about 0-0.014 VDC on the other side... Seems strange to me.
Edit: Now I think that it's because my multimeter is to slow to pick up the fast pulse. Guess the problem is the C5 cap and that it doesn't hold. Will try some others.
What is the function of the D3 diode? When I emulate the circuit this one messes up the whole thing, when I remove it all works...
robboten
PostPosted: Sun Dec 23, 2012 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Sticking to my monologue here... Wink
My simulator had the wrong pic for N-fet/P-fet so thats why the diode messed up.
My working hypothesis now is that the source has a negative voltage to begin with so the jfet is constantly open. I will do further research.
robboten
PostPosted: Mon Feb 25, 2013 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Ehm... I just wanted to tell you that I had misunderstood the function of the S&H module. I thought it would generate sound, not modulate an VCO for example. So all well now! Smile
Audio files: 116
G2 patch files: 317
PostPosted: Mon Feb 25, 2013 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, a learning process documented :-)
JuneSolstice2013
