-minus-
Posted: Wed Aug 22, 2012 11:58 am Post subject:
Good to hear it's working for you. If you are looking for an amp, you could make a little gem or a ruby amp found here:
http://www.runoffgroove.com/littlegem.html
Oh, and those diagrams I did were done with Adobe Illustrator... |
stealthop
Posted: Fri Aug 31, 2012 10:41 am Post subject:
hi there , i was wondering about the 1n4148 diode. are you using the glass switching type or the rectifier type? any help would be greatly appreciated
thanks |
-minus-
stealthop
Posted: Fri Aug 31, 2012 7:05 pm Post subject:
| ahh , thank you . that means i have everything i need to start building this. |
Denis_Veselov
Denis_Veselov
Denis_Veselov
Posted: Wed Nov 28, 2012 1:17 am Post subject:
| Denis_Veselov wrote: | | or so maybe: |
I'll build this circuit on my breadboard, but it isn't working.  _________________ Sorry my english |
-minus-
Posted: Wed Nov 28, 2012 1:29 am Post subject:
Ok. So are you getting any part of it to work? Is there any sound?
First thing to check is the power supply. If you are using a battery has it got power in it? Then you need to check the power is getting to the I.C's. Make sure all the grounded components are connected.
If you are getting power to the board correctly, you should check that the clock is working and then move on to the 4017 counter. |
Denis_Veselov
Posted: Wed Nov 28, 2012 1:39 am Post subject:
So i think, if to break all left wires (see circuit) of 8 pots, it will start give the sound in all its range.
But it make new problems:
1) Impossible to make a silence in anyone channel.
2) If all pots stay in left position, 8 tones have a some difference of tones. _________________ Sorry my english |
Denis_Veselov
Posted: Wed Nov 28, 2012 1:46 am Post subject:
| -minus- wrote: | Ok. So are you getting any part of it to work? Is there any sound?
I just said about my changed circuit. It have a sound, but in second half range of pots. _________________ Sorry my english |
-minus-
Posted: Wed Nov 28, 2012 2:08 am Post subject:
Sorry I was unsure what you meant. So you have sound but the changes you suggested haven't worked.
To silence a channel you could use switches maybe. But that won't help the difference in tones problem.
What about reducing the 50K resistors you suggested using on the 8 steps. Perhaps you could try that? |
Denis_Veselov
Posted: Wed Nov 28, 2012 10:38 pm Post subject:
This changes haven't worked too. _________________ Sorry my english |
-minus-
Posted: Wed Nov 28, 2012 11:03 pm Post subject:
| Im just wondering what pots you are using. Linear (B) or Logarithmic (A). Log pots would tend to bunch up the usable range towards one end and would appear worse than linear in this application. Maybe check that. |
Denis_Veselov
Posted: Thu Nov 29, 2012 7:02 am Post subject:
Pots have a mark: "B100K" (or "B50K" for changed circuit). _________________ Sorry my english |
Denis_Veselov
Posted: Mon Dec 17, 2012 9:39 pm Post subject:
Hi!
I want to add any interresting and simple filter to my apc+seq. Anybody have a circuit? Thanks. _________________ Sorry my english |
Denis_Veselov
-minus-
Posted: Sat Dec 22, 2012 7:22 pm Post subject:
Excellent! Glad you got it working. Looks like the whole family is enjoying it.  |
Denis_Veselov
Posted: Sun Dec 23, 2012 12:18 am Post subject:
| -minus- wrote: | Excellent! Glad you got it working. Looks like the whole family is enjoying it.  |
Thanks! Your stripboard is very cool. _________________ Sorry my english |
RotomotioN
Denis_Veselov
Posted: Sun Mar 03, 2013 10:05 pm Post subject:
I tried to go on this link, but I saw "Page not found". _________________ Sorry my english |
bubzy
Joined: Oct 27, 2010 Posts: 450 Location: United Kingdom
Audio files: 47
Posted: Mon Mar 04, 2013 4:49 am Post subject:
you can look up a simple "RC" filter. its 2 components or you can make it a bit nicer with an op amp as well. depends really on how much you want to do with it.
or you can look here :
http://electro-music.com/wiki/pmwiki.php?n=Schematics.Listbytype
and scroll to the filters section  _________________ _Richard_  |
Audio files: 254
Posted: Mon Mar 04, 2013 5:37 am Post subject:
| RotomotioN wrote: | Hi, first post, great thread. Will be building soon .
Denis: Pots marked "B" are logarythmic, marked "A" are linear. You need A |
It actually depends on the manufacturer. Most pots I use (Piher & Omeg) do indeed have an 'A' marking for linear, and a 'B' for logarithmic. However
alpha pots. and probably some other brands too, have this the other way around. (this can also be somewhat confusing in schematics when
they only use an 'A' or 'B')
btw.
as for a filter, I recently used a simple sallenkey filter in a bend keyboard, which sounds pretty good.
Downside is that you need a stereopot. for the cutoff frequency, but it also has resonance control which is nice. _________________ "My perf, it's full of holes!"
http://www.acidtrash.com/ Last edited by PHOBoS on Wed Mar 06, 2013 6:08 am; edited 1 time in total |
analog_backlash
Joined: Sep 04, 2012 Posts: 244 Location: Aldershot UK
Posted: Mon Mar 04, 2013 6:59 am Post subject:
| PHOBoS wrote: | | It actually depends on the manufacturer. Most pots I use (Piher & Omeg) do indeed have an 'A' marking for linear, and a 'B' for logarithmic. However alpha pots. and probably some other brands too, have this the other way around. (this can also be somewhat confusing in circuits when they only use an 'A' or 'B') |
You frightened me for a moment there PHOBoS, but then I read it again. I assumed that A was LOG and B was LIN, but it turns out this is true for Alpha pots AND TruOhm pots (which account for most of the ones I have). I'll be a bit more careful in future not to assume that A and B mean anything!
Gary |
RotomotioN
Posted: Tue Mar 05, 2013 4:07 pm Post subject:
Ha! Didn't know that. It makes it all the more confusing. Just get your meter and be sure!
@denis: link works fine here |
analog_backlash
