Moog Transistor Ladder Filter Resonance not Working
Page 1 of 1 [11 Posts]
smokestacksproductions
PostPosted: Sun Dec 16, 2012 10:50 am    Post subject: Moog Transistor Ladder Filter Resonance not Working Reply with quote  Mark this post and the followings unread
Hello,
I could not find an Antilog pot at my supplier so I used a linear pot instead. The resonance pot has no effect at all, the filter will not self-oscillate, etc. - I have tried adjusting the trimmer, but there is no difference. Any tips?
Audio files: 27
PostPosted: Tue Dec 18, 2012 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
The use of a linear pot will not prevent the resonance control from having an effect.
Check your solder joints and polarity on C11, and where your pot connects to the pcb. Check your solder joints on T3 and R18. Also, check soldering on R15 and R17.
If you etched your own PCB, make sure that there are no breaks in the traces at or near these components.
Hope this helps -- this filter is really nice and you will enjoy it once it is up and running.
analog_backlash
PostPosted: Wed Dec 19, 2012 3:32 am    Post subject: Pseudo Antilog Pot Reply with quote  Mark this post and the followings unread
As Kevin has already said, the pot choice is not going to cause the problems that you have encountered. However, if (sorry, when) you do get it working, you could try the following alteration to give a pseudo-antilog 50K pot. You just need to replace the Emphasis pot with a 100K lin pot and connect a fixed 100K resistor in parallel across it, as shown. I've also shown the graph of resistance vs. rotation (theoretical) showing the shape of the resistance curve.
I only discovered this after looking at a circuit that Uncle Krunkus had posted, so this web site is very educational!
Gary
WRONG! See below
 Filesize:  15.28 KB
 Viewed:  38 Time(s)
Last edited by analog_backlash on Mon Dec 24, 2012 8:43 am; edited 1 time in total
PostPosted: Fri Dec 21, 2012 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
ok,
I got the filter working properly, it was bad wiring....
anyways, I tried a 100k linear pot with a 100k resistor across the two lugs that are wired to the board, but It seems like there is little effect until the last 1/4 of roatation (kind of like a regular LOG pot)
I'm thinking I might be better off with the 50k linear. Or does anyone else have a source for the 50k antilog pots?
analog_backlash
PostPosted: Fri Dec 21, 2012 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Strange that, I thought that it should work better than the 50K linear. I've seen other descriptions where they wire the 100K fixed resistor across the 2 outermost lugs of the 100K linear pot, which might give a better result (I haven't done the maths yet).
Anyway, Small Bear have 50K reverse audio pots:
http://www.smallbearelec.com/servlet/Detail?no=116
See also these two articles which cover changing the taper of a pot:
http://sound.westhost.com/pots.htm
http://www.geofex.com/Article_Folders/potsecrets/potscret.htm
Gary
ADDITIONAL: Just checked that out on my spreadsheet and you do get a different shaped curve (see attached). It's steeper at first and it flattens out more towards the end. It might be worth trying.
WRONG! See below
 Filesize:  5.54 KB
 Viewed:  1124 Time(s)
Last edited by analog_backlash on Mon Dec 24, 2012 8:44 am; edited 1 time in total
yusynth
PostPosted: Sat Dec 22, 2012 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
analog_backlash : this is a very common mistake. You obtain a log curve not a rev-log curve as required. One definitely need a reverse log pot C curve, the taping trick won't work !
Yves
analog_backlash
PostPosted: Sat Dec 22, 2012 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that Yves Embarassed Just goes to show that you can't believe everything you read on the internet! That would explain the problem. Those antilog pots do seem difficult to obtain now. I noticed that you said you get them from Das Musikding, but I looked there and they don't seem to have any at present. Are there any other sources?
Gary
Cardinen
PostPosted: Sat Dec 22, 2012 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Musikding
http://www.musikding.de/Passive-parts/Potentiometers/Alpha-Pots-16mm/Mono/Alpha-Potentiometer-16mm-50k-rev-log::895.html
Banzai
http://www.banzaimusic.com/Alpha-16mm-FS-50k-REV-log.html
yusynth
PostPosted: Sun Dec 23, 2012 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Cardinen said it Wink
Yves
analog_backlash
PostPosted: Sun Dec 23, 2012 3:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for that Cardinen/Yves. I clicked a box labelled "rev log" on Das Musikding and it replied "Product not found!", that's why I thought that they didn't have any.
Gary
analog_backlash
PostPosted: Mon Dec 24, 2012 9:19 am    Post subject: I WAS WRONG!!! Reply with quote  Mark this post and the followings unread
Hi Yves (et al.).
I was initially a bit baffled by this antilog pot thing (probably because I believed certain posts on the internet which were also wrong), so I thought about it and realised my error! I was not comparing like with like. My plots are basically resistance vs. percentage turn of the pot, whereas I should have been thinking about percentage output vs. percentage turn. When I tried this out (for my first circuit idea), the graph I got looked more like a (pseudo) log plot (see attached - blue = linear pot, red = linear pot with parallel resistor).
I've admitted my error and edited my posts above, so that other people don't read them and fall into the same trap!
Apologies, Gary
 Filesize:  6.69 KB
 Viewed:  934 Time(s)
