  PHOBoS presents: Deep Journey 3 {Going Deeperer}
Chain and loop multiple LFOShpA modules?
Page 1 of 1 [2 Posts]
MiCR0C0SM
PostPosted: Thu Dec 27, 2012 7:16 am    Post subject: Chain and loop multiple LFOShpA modules? Reply with quote  Mark this post and the followings unread
Still a noob three years into owning a g2 and learning everyday. Was wondering if anybody had some tips on how I could chain, clock, and eventually loop multiple LFOShpA modules to shape a sound? How can I have one start when the previous completes? Or do I have all shape the sound at once and somehow route from each of the LFOs in a sequence? As you can tell, all I truly have at this point are random thoughts...
Finally, am I going about it all wrong and should I use envelopes somehow instead?
Thanks in advance!
Audio files: 218
G2 patch files: 319
PostPosted: Thu Dec 27, 2012 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. you could stop one by setting the dir input to zero, not sure if they'd be chainable ... interesting question, but looks like it would get complex soon.
Another option for shaping would be to use a sequencer ... the control sequencer is able to do interpolation between steps (XFade option), and you could control it from a saw wave LFO (setting the right amplitude) .. this one is easy to make and would give some more steps than a multi envelope module.
Not sure what complexity you're after.
Edit: you can also chain a couple of control sequencers, and then mix them through a cross fader or the cross fading 8->1 multiplexer.
Edit 2: some of the envelopes are chainable too, but they'll only trigger the next one when the output has gone zero I think.
