  Faux Pas Quartet and friends Music From Last Thursday [rebroadcast]
PCB offer: Thomas Henry's 555-VCO
Page 2 of 6 [131 Posts]
aladan
PostPosted: Sat Dec 22, 2012 7:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias,
Please put me down for 2 (main PCB only) at this stage. Hopefully more, but money is tight Sad
2x circuit PCB
A.
bod
PostPosted: Sun Dec 23, 2012 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd be down for 2 of each of the circuit pcb and the eurorack pcb Smile
Sony Crocket
PostPosted: Tue Dec 25, 2012 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi!
Please, put me in the list for 3 circuit PCBs
Thanks and merry xmas!
Feedblack
PostPosted: Wed Dec 26, 2012 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
hi matthias,
count me in please
1x eurorack PCB
1x front panel (depending on price)
Heavy Metal Kid
PostPosted: Thu Dec 27, 2012 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm interested in:
2x eurorack PCB
2x front panel (depending on price)
PostPosted: Thu Dec 27, 2012 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Feedblack wrote:
hi matthias,
count me in please
1x eurorack PCB
1x circuit PCB
1x front panel components PCB
1x front panel
correct?
fonitronik at
PostPosted: Thu Dec 27, 2012 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Heavy Metal Kid wrote:
I'm interested in:
2x eurorack PCB
2x circuit PCB
2x front panel components PCB
2x front panel
correct?
fonitronik at
Feedblack
PostPosted: Thu Dec 27, 2012 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
Feedblack wrote:
hi matthias,
count me in please
1x eurorack PCB
1x circuit PCB
1x front panel
correct?
Hi Matthias,
seems that I missunderstood which PCP's I need. So the Eurorack panel is only for the pots, and jacks...yes, in this case I need:
1x circuit PCB
1x front panel
thanks,
Claus
PostPosted: Thu Dec 27, 2012 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
seems quite confusing, no? this is just because we wanted to have generic PCB that could be used for builds in all formats (MTA-100 headers, manual wiring), and later on the eurrack people (a strong lobby) voted for an additional front panel components PCB (no wiring, easier for newbies).
and in the end i decided to provide a front panel as well...
fonitronik at
Feedblack
PostPosted: Thu Dec 27, 2012 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
that's fine. I prefer too frontpanels and frontpanel PCB's. I have to buy a frontpanel anyway (if not, it does not look good, I have two left hands with ten thumbs). And putting the things together is allways the tricky part... at the moment I have here the Liquid HiHat, and with panel and PCP I have to get some brass, cut it a.s.o. to make an angle to bring the things together....
Sony Crocket
PostPosted: Fri Dec 28, 2012 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias,
Could you tell us the reference number or model of the pots and jacks needed for the eurorack pcb?
If there are no rare parts or plastic shaft pots, I think it will be great not having to do the wiring...
PostPosted: Fri Dec 28, 2012 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
for the pots i used 9mm Alpha (mouser, smallbear, banzai et. al.). i ordered 9mm Alps, they should arrive tomorrow. i think they will fit, too.
the jacks are PJ-301B. you get them from
Erthenvar (USA)
or
Thonk (Europe)
fonitronik at
Heavy Metal Kid
PostPosted: Fri Dec 28, 2012 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Having read the thread more carefully, I'd like two eurorack PCBs in addition to the two circuit PCBs and the two Euro front panels.
Last edited by Heavy Metal Kid on Sat Dec 29, 2012 7:00 am; edited 1 time in total
insider
PostPosted: Sat Dec 29, 2012 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
3x circuit PCB for me.
thanks.
Danno Gee Ray
PostPosted: Sat Dec 29, 2012 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would like to ammend my earlier stated order.
2x Circuit PCB
1x Front Panel PCB
1X Eurorack Panel
Thank you very much.
talks
PostPosted: Wed Jan 02, 2013 12:11 am    Post subject: Reply with quote  Mark this post and the followings unread
2x Circuit PCB
TheProf
PostPosted: Thu Jan 03, 2013 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Could I put myself down for 2 circuit PCB's. Thanks.
Mike
LektroiD
PostPosted: Fri Jan 04, 2013 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
2x VCO PCB's for me please. Maybe more depending if I can revive my existing oscillators or not.
*EDIT*
I would like to bump my order to 4x VCO PCB's
My tunes available here
(check out the new Electro-Funk LP)
PostPosted: Sat Jan 05, 2013 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
i finished the 2nd prototype tonight (the new one with the eurorack front panel components PCB). first i had a short (did not cut legs properly), then i found a trace missing, which i had to bridge, and eventually i lowered R27 by mounting a 33k in parallel, thus the PCB looks a little bit worn out, hehe. anyways, the boards you order will be 100% correct (nomissing traces).
TH_555-VCO new by fonitronik, on Flickr
fonitronik at
LektroiD
PostPosted: Sun Jan 06, 2013 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Will you be offering tempcos for this? I find these things near impossible to source...
PostPosted: Sun Jan 06, 2013 10:41 am    Post subject: Reply with quote  Mark this post and the followings unread
i recently bought 100pcs from pata for 40 yen each (~40c)!
his page is here: http://www.mmslab.jp/parts.html
the page is in Japanese, nevertheless, english is fine for email communication and he is a really nice guy. he provided me with tracking information from the japanese postal service via email. paypal is ok. hover your mouse over one of the links on the page to get his email address (3rd from the top)
the tempcos available are
LT16S102F33 (1k)
LT16S202F33 (2k)
the component# breaks down as
LT - type
16 - 0.167W (1/6W), enough for tempco duties
S - package, common through hole resistor
102 - 1k
F - 1% tolerance
33 - 3300ppm/C
datasheet: http://www.akaneohm.com/catalogue/LT.pdf
(thanks to andrewF for the hint!)
fonitronik at
aladan
PostPosted: Sun Jan 06, 2013 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
LT16S102F33 (1k)
LT16S202F33 (2k)
LT - type
102 - 1k
F - 1% tolerance
33 - 3300ppm/C
He is a great guy, I put through a big order with him recently and he shipped it bar one NE5534 that was out of stock. He sent that NE5534 in a tiny, tiny package a week later at his own expense. You can't ask for more than that.
He also has some Akaneohm 1.87K tempcos in stock! I only found out after my order went through and I have a pile of the big KRLs from the recent group purchase now anyway.
A.
LektroiD
PostPosted: Tue Jan 08, 2013 1:28 am    Post subject: Reply with quote  Mark this post and the followings unread
LT16S102F33 (1k)
LT16S202F33 (2k)
LT - type
102 - 1k
F - 1% tolerance
33 - 3300ppm/C
A.
A quick question, has anyone used standard mail, or is it recommended to use "registered" at an additional 410JPY?
PostPosted: Sat Jan 12, 2013 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
i used standard mail, however, he sent it registered with full tracking service Cool
fonitronik at
i will take orders until 19 JAN 2013, then i will order all PCB and front panels.
fonitronik at
JuneSolstice2013
