Add power jack to WSG
Page 1 of 1 [2 Posts]
kingnimrod
PostPosted: Fri Dec 28, 2012 5:24 pm    Post subject: Add power jack to WSG Reply with quote  Mark this post and the followings unread
Couldn't find this info anywhere. Does someone mind making a diagram of how to convert the wsg from battery power to 9v power jack?
Also,modes the power starve mod work with wall power?
capicoso
PostPosted: Sun Dec 30, 2012 1:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Just buy a 9v dc wall wart. Then a dc jack i think most are 2.1mm. It has two or three terminals, there are two that are the same, so with your dvm check to see which ones are the same. Then all you have to do is wire one terminal to the + switch on the wsg and the gnd to the jack(if you did it like the panel wiring from ray wilson)
http://www.google.com/imgres?imgurl=http://prodmod.com/wp-content/uploads/2008/10/snap-in-dc-jack-polarity.JPG&imgrefurl=http://prodmod.com/make/rebattkit/&h=488&w=532&sz=36&tbnid=nNgJMe7qAA96DM:&tbnh=104&tbnw=113&prev=/search%3Fq%3Ddc%2Bjack%2Bnegative%26tbm%3Disch%26tbo%3Du&zoom=1&q=dc+jack+negative&usg=__ICOYKVaziJHioUJn82_fA0sx9L8=&docid=kogoDFDUU064HM&sa=X&ei=cfTfUKj1KYnA9QTa5oDQAw&ved=0CDMQ9QEwAA&dur=2486
http://www.google.com/imgres?imgurl=http://www.beavisaudio.com/techpages/PedalPower/PowerJack1.gif&imgrefurl=http://www.beavisaudio.com/techpages/PedalPower/&h=165&w=278&sz=7&tbnid=PY_Ei1AlVFT8dM:&tbnh=71&tbnw=120&prev=/search%3Fq%3Ddc%2Bjack%2Bnegative%26tbm%3Disch%26tbo%3Du&zoom=1&q=dc+jack+negative&usg=__tpXmSu1j-_D5j6g2St3fOkRicKU=&docid=I2QHXO2i6-EjeM&sa=X&ei=cfTfUKj1KYnA9QTa5oDQAw&ved=0CDYQ9QEwAQ&dur=5876
good luck
