Soundlab build
Page 1 of 1 [13 Posts]
PostPosted: Tue Nov 27, 2012 9:57 pm    Post subject: Soundlab build
Subject description: There are many like it, but this one is mine (well, actually someone else's)
But the panel design is mine Smile Heavily derivative, but still mine Smile
 Filesize:  333.09 KB
 Viewed:  128 Time(s)
 Filesize:  199 KB
 Viewed:  133 Time(s)
 Filesize:  273.81 KB
 Viewed:  138 Time(s)
cds56
PostPosted: Wed Dec 05, 2012 6:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like it better than mine Smile I like that your front panel is actually silk screened... I had no way to do that so I just kinda improvised...
lookin goood!
PostPosted: Wed Dec 05, 2012 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, for versions of "silk screened" which include using labels on an inkjet... Smile
Since it was a build for someone else, i wanted it to look a bit professional. I really enjoyed playing with it, but it's on its way now. I will probably build the SL+ from the stripboard version I've seen around here, at some point.
PostPosted: Sat Dec 08, 2012 8:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gonna try to build a SLMS+ in a cigar box. I think the big challenge will be that the particular box that has enough panel space is also short, so vertical space is going to be a challenge. I am going to have to take a different approach than usual to my wiring, I think....
PostPosted: Mon Dec 10, 2012 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Make sure you use finer wire. Shocked
I know this sounds obvious, but can be overlooked when space is at a premium.
I've found that some old printer cables (D25->Centronix (op-shop)) have nice fine easily soldered wires, which still have 7 or so strands each. A small bit of heatshrink where they meet the board/component will insure against problems later, looks good, and doesn't really take much more time. Wink
PostPosted: Mon Dec 10, 2012 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Would you say that was finer than 24 AWG? I don't have any strippers that go finer than that. I could definitely see my usual 22 AWG being a problem though, so good point, and one I hadn't really thought about. I *had* been thinking about ribbon cable though....
PostPosted: Mon Dec 10, 2012 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, ribbon cable would be my next choice.
Get the rainbow coloured one to help trace things out though.
A mass of grey wire can be hell to troubleshoot.
PostPosted: Mon Dec 10, 2012 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yep, definitely rainbow ribbon cable. I just need to make a count of the number of necessary connections, and my small ribbon cable experience so far shows that I have some difficulty with initial cuts without damaging wires....
PostPosted: Sat Dec 29, 2012 12:26 am    Post subject: Cigarlab+ Reply with quote  Mark this post and the followings unread
Approaching the end of the second build in the cigar box....
I've got the box prepped, boards soldered and stuffed, power connections made and tested.... The ribbon cable (and a handful more that aren't worth really doing ribbon cable for) is all that really remains.
 Filesize:  558.48 KB
 Viewed:  114 Time(s)
ashleym
PostPosted: Sat Dec 29, 2012 5:13 am    Post subject:   Reply with quote  Mark this post and the followings unread
Looks good. But isnt it still illegal to buy or even smoke Cuban cigars in the US? Question Question Question You need to 'fess up Laughing
PostPosted: Sat Dec 29, 2012 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Lucky for me, this is a Honduran cigar box Very Happy
PostPosted: Mon Dec 31, 2012 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I love a successful project to end the year:
synthcube
PostPosted: Mon Dec 31, 2012 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
very nice
i built my first Ray Wilson design (wierd sound generator) in a leftover Banfi Brunello wine box Razz
great stuff
